Question about Canon imagePROGRAF W8400 InkJet Printer
ERRORE E0200D plotter canon W7200 - Canon imagePROGRAF W8400 InkJet Printer
Hi. I have a problem printing the bar code symbol is similar to
Posted on Jul 24, 2012
  • 79 Answers
SOURCE: i have the canon
check the paper selection button. Is cut sheet or roll paper?
Posted on Oct 30, 2008
SOURCE: Problem in w7200
Hi - I had a different problem involving the carriage, but the solution may help you. There is (or should be) a pin on the carriage, visible on the right side when you lift the plastic pieces that hold in the printhead. This pin is about 2 in long and varies in diameter from about 1/8 inch diameter to 3/16 inch diameter. If this pin is not there, which in my case it had fallen down into the ink purge unit, the black will be shadowed by magenta. I don't know how to fix that part, but if the pin is gone you may soon have a bigger problem, which is the pin binds in the gears of the ink purge system and the printer won't do anything after that. Check for the pin, and if its gone and you live in an area where someone can service your machine call them up! In my case i was able to dig the pin out myself and the printer works again, but there is a slight overshadow of magenta.
Posted on Nov 28, 2007
Could be that the button for Sheet / Roll has been pressed. This is a popular error caused by the machine expecting a sheet when you are loading a roll. Make sure the light is located on the roll option rather than the sheet.
If this is the problem, you must first remove all media, then lower the covers and lower the media release lever before the printer will allow you to change between roll & sheet.
Posted on Dec 05, 2008
SOURCE: Canon W7200 Error code E02D05
E02D05
Air flow fan error Airflow is not detected
1.Cable connection check
Replace the cable between the air flow fan and engine controller if the connection is
not functioning normally.
2.Replace the air flow fan.
3.Replace the engine controller.
4.Replace the system controller
Cheers Edwin
Posted on May 14, 2009
SOURCE: plotter canon w7200
HO il medesimo problema...come l'avete risolto?
Grazie
alberta
Posted on Oct 02, 2010
Hi my plotter always print a blue color on all pages.for each kind i print i have it has no differences.does any one knows about my problem? my plotter model is Canon W7200 thanks best regards
Try printing the Nozzle Check pattern. Check if colors are printed correctly. If not, try Printhead Cleaning A first then check again the Nozzle Pattern. If there's a small changes to the pattern, try Printhead Cleaning B. If problem persist, try changing the Printhead.
Oct 09, 2014 | Canon imagePROGRAF W7200 InkJet Printer
No 64 bit driver for Canon W7200
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 21, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Plotter canon w7200
Grazie
alberta
Feb 10, 2009 | Canon imagePROGRAF W7200 InkJet Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
W7200
Take it out and clean all contacts, worth a try as they cost £500 from canon. An engineer told me they usually only last about a year and after problems with the cutter failing and colour problems in drawings we got a new one which fixed the problems. Third new printhead in 4 years, canon should be ashamed.
Oct 07, 2008 | Canon imagePROGRAF W7200 InkJet Printer
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Canon imagePROGRAF W8400 InkJet Printer Logo
411 people viewed this question
old marine
old marine
