Question about MTX LOLITA 8" 100 WATT LOW PROFILE SUBWOOFER Speaker
MTX Lolita Sub amp defective power transformer (open primary) What's the transformer voltage?
  • 55 Answers
Without Knowing the Output Chip or transistor Numbers, I don't know but Most 100 Watt anps use 60 to 70 Volt Centertap Sacondarys. Also if You Take the Cover off The Transformer you will find a Thermal Fuse in the Primary. I have bypassed the Thermal Fuse and went with a external fuse, Go for it.
Posted on Oct 08, 2010
No power light on my hitachi modelcx-36w cd tape radio player but power to the machine the fuse is fine
If the radio has a power transformer check there is AC voltage to the primary "fuse side", [ 2 wires ] if yes check the secondary side, if no AC voltage is present the power transformer is open at the primary. The part must be replaced.
Jun 12, 2012 | Audio Players & Recorders
Model 721.64282 microwave/convection oven - microwave not heating and making a loud noise. convection oven works
No heat but otherwise normal operationA shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
Oct 21, 2010 | Kenmore 63663 Microwave Oven
I have a MTX 4105D amp and it cuts in and out what could it be
could be not enough voltage or the settings on the amp are not correct for the sub you have its a feature that MTX put on thier new amps
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
Amp and sub have been working great together then all of a sudden the amp is not putting out enough power to push the sub. MTX Thunder 311D
check to see if one of the RCA cables is unplugged or bad. check the gain check the sub level control on the deck if yours has one.
May 19, 2010 | MTX Thunder 311D Car Audio Amplifier
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Mtx 7500 sub
what amp are u usin?What enclosure 4 speakers do u have?Might not have enouigh voltage 4 the amp.How big are the wire for power 2 amp?what ohm are you playing ,is it compatible to the woofers.Need more info.Model and makes please,but 1st a rating.
Jun 16, 2008 | MTX Car Audio & Video
MTX LOLITA 8" 100 WATT LOW PROFILE SUBWOOFER Speaker Logo
143 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
