Question about Kenmore 64882 Electric Dryer
The belt on my dryer broke I need to know how to replace it
    President:
  • 2,992 Answers
This site has a good illustrated procedure to follow for changing your belt. (The site says Whirlpool, but it's the same for Kenmore.) It's not a tough job if you're patient and comfortable with simple tools (like a screwdriver). The same site sells the parts, and you can usually find the belt locally at a well-stocked appliance parts store.
Good luck with the repair, and thanks for using Fixya!
Posted on Oct 07, 2010
  • 1314 Answers
SOURCE: Changing the belt on Frigidaire GLER642
ok here we go facing the drier take a putty knife come about 1-2 inches from the edge and push in should feel a spring clip depress in lift one side then the other look inside on the front panel and remove the two 5/16 inch screws grasp the front and snap it off give it a good tug then your ready to go be sure to un plug the drier and slide it out from the wall so you can tilt the top back before removing the front don't forget my 4 boxes and make sure the idler pulley is on the belt the the belt goes around the drum around the motor pulley then you pull the idler pulley back and put the belt on top of the idler pulley let it back against the belt to keep the belt tight you do not have to remove the drum for this can all be done from the front
Posted on Jan 11, 2008
  • 177 Answers
SOURCE: changing the belt on my admiral dryer
Go to partselect.com and look up a belt for you admiral dryer.
At this site they may have a diagram for how the belt goes on the cylinder, idler wheel and motor.
Start here, more later as needed.
Posted on May 07, 2008
  • 160 Answers
SOURCE: Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
Posted on Jul 10, 2008
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
  • 111 Answers
SOURCE: belt broke cant find where to take apart to replace belt
Most dryers can be taken apart on the back. Take out the screws holding the rear plate on and you should see the motor and pulleys. It's always good to keep the back oof of the unit until you test it once. The belt could be getting broken or just slipping off due to overloading the unit. Over time, this can severly damage the rollers and put too much tension on the motor assembly. Hope this helps.
Posted on May 24, 2009
NEED TO REPLACE THE FAN BELT ON HAIER DRYER MODELHLP140E
Remove the lint trap. There is a bolt in the center. Remove bolt. Remove screws from crossbar and you can then replace the belt. I removed sensor and lifted drum out makes it easier. Pay attention to how black belt is thread if removed
Apr 04, 2014 | Haier HLP140E Electric Portable Dryer
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
Asko Dryer model T-701
you need to replace the motor you can replace the rear half of the motor but you can only buy a complete motor.this isnt a common problem but i have had it before.it broke because you need to grease the pin every 5 years or so.
Oct 24, 2008 | Asko T711 Electric Dryer
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Changing the belt on my admiral dryer
May 06, 2008 | Dryers
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 64882 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
