Question about Refrigerators
Hi my husband has bin defosting the fridge freezer and hit somthing now gas is spraying out is this harmful?
    Sergeant:
    Champion:
  • 351 Answers
Not good for you in a confined space open a door or a window until it stop leaking out
Posted on Oct 08, 2010
Ge side by side.. freezer randomly defrost's. gets warm enough to melt all the ice in the ice bin.. there is a lovely ice sculpture in the fridge now as it refroze when dripping out. is there a way...
The only thing you could do is replace the defrost thermostat...its the part that determines when the defrost heater cuts off....typically it cuts off the heater around 40 degrees (the defost system is comprised of only 3 parts..the heater..the control....and the thermostat)
GENE
Sep 15, 2011 | GE Refrigerators
I have a micro fridge and the fridge is not cooling bt the freezer is cooling but not as it should i have the temp to the coolest and the fridge is still not cool what could it be?
it may be frosted up in the freezer behind the back wall, if there is frost build up on the back wall then you need to test the defost circut, termination therm, element and defrost timer
Jul 16, 2011 | Kenmore Side by Side Refrigerator
Fridge sectipon of fridge freezer started making a
Replace the fan motor or at lest take the cober off and cneck to see if there is ice build up or somthing has got to where it hitting the blades.
Jun 06, 2010 | Refrigerators
KitchenAid fridge model #EE4412201, freezer is NOT defrosting. Air tower iced up a little, freezer floor all ice. water in back of fridge. Freezer is cold, fridge isn't. I cleaned the freezer, took the...
try a new defrost timer. or new kit defros timer defrost terminator and heater. tfound the timer rotate, open the freezer. if you hear a noise like ICE BREAKING. your onli problem is the timer. really important after repair your fridge. allow at least 24 hr for defost the whole evap. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
Unusual Noise
The compressor and condenser fan are at the back. The fan could be hitting somthing. The internal parts of the compressor could make a noise usually when it cut on or off.
Sep 02, 2009 | Refrigerators
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
My Kenmore fridge/freezer side by side isn't staying cold
Ok so we just had our Kenmore fridge quit cooling , everything in the freezer defrosted , and we lost a lot of food,BUT my husband ordered a part #8201786 which is a starter , and installed it and it worked! The fridge was clicking but it just wouldnt kick on, and the fan still worked. There are websites that you can order the part from, It cost $63.05 with tax!!!! good luck
Mar 15, 2009 | Kenmore 53642 / 53644 Side by Side...
There is gas leaking from our fridge freezer
You punctured the coolant line. It will definitely need to be serviced ASAP. I would advise against using it and it should probably be unplugged (it's not going to work now, anyway...).
Sep 22, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
