Question about Hampton Bay 46056 Callaway II Ceiling Fan
In my Hampton Bays ceiling fan is a circular fluorescent bulb which gives very poor light. Is it possible to put in a different lighting system like hallogen?
  • 447 Answers
Yws it is possible.Check on the fan before changing anything, there should be a maximum wattage sticker. Do not go any bringter than the max, it is there for a reason. If your plans are to install incondesent light system, be aware. that, bulb puts out much more heat,
Posted on Oct 08, 2010
I need a replacement LED light bulb or kit for my Hampton Bay fan model number AM215-BN. Where can I get one?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Light-Kits/Hampton-Bay/N-5yc1vZc5t3Zp4
Aug 14, 2016 | Hampton Bay Dryers
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
Hampton Bay 52" Oil-rubbed bronze
If it's a Hampton Bay light kit, it should be no problem putting it on their fan.
Sep 04, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
I am having issues getting bulbs due to the base size. It is in between a reg light base for standard bulb and the small base used for decorative lighting. The base is approx. size of a dime (Hampton Bay...
They actually have bulbs that are just made for ceiling fans, but can also be used for other things as well. You can get these bulbs at Home Depot, Lowes, etc. You might bring the bulbs with you if possible as sometimes it can get confusing after looking at twenty different designs. Hope this helps.
Jan 01, 2010 | Hampton Bay 52 In.Carriage House II in...
Ceiling fans not bright enough
In this case, probably not. The issue is heat, and the limit is space. One suggestion, new fluorescent bulbs give more light with less wattage. If you can find one that will physically fit in the space, this might get you more light.
Oct 19, 2009 | Aloha Housewares Dryers
Change light
i just put fluorescent lights in two of these fans. it just takes a little fabbing and its done and simple.
Go to home depot and buy a lithonia lighting 11" low profile round light model# FM22 ACLR LP.
tools:
drill
rotozip or file
wire strippers
crescent wrench
screwdriver(phillips)
you can take the neons and the power supply off of the fan base but be sure to save all the screws, you will need them later. the ballast in the light will fit in the chrome base on the fan but you have to shave one of the bolt holes down first for it to fit (be sure not to cut the ones that the bolts go through). you do not need the green ground wire from the new light.
Next drill out the rivets from the bulb brackets on the new light base. now you can take the bulb and place it on the fan backing plate and get your bulb brackets and mark where you will mount them. then drill holes for them (but make sure the holes are for the screws that you saved earlier because you will reuse them for the light brackets). Be sure to mount the bulb as center as possible.
now once you have fabbed everything put the assembly up to the fan and pull the wires down through the ballast and through the center tassle bolt and wire it up. the bulb is an 8" bulb and thats all that will fit. home depot sells phillips 8" bulbs in several different brightnesess.
this picture was taken on my phone so it isn't that great. but the light really brightens it up.
Oct 08, 2009 | Hampton Bay 37225 Cameron II Plus Fan
I purchased hampton bay 4 pack solar led landscape lights 237 002 - 2 lights work, 2 don't, I put in new batteries but still can't get them to work - they have been outside for a month. They worked last...
Sun burns out the photocell in lights. Hampton Bay uses cheap components in their Fans and Lighting all made in China for a fraction of what you paid. Dont waste time calling gpwarranty.com they dont care.
Best option..buy a good set and dont buy them from Home Depot, Hampton Bays primary retailer, sort of voting with your wallet.
Sep 23, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Mar 01, 2009 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Light bulb socket uses intermediate base bulbs, not standard bulbs. I want to put in compact fluorescent lamps (lightbulbs) in my hampton bay huntington fan. I either need to use an adaptor to change to...
I found the solution on the web. The only place it looks like that has this adapter is voss lighting. Here is a link to the adapter. http://www.vosslighting.com/storefrontB2BWEB/itemdetail.do?action=prepare_detail&itm_id=18159&itm_index=7
Sep 18, 2008 | Hampton Bay 52 In. White Huntington III...
Hampton Bay 46056 Callaway II Ceiling Fan Logo
463 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
