What is the script to make our own bach file .exe program
  • 25 Answers
Please follow this link to the Bach File Script:
http://sysadmingeek.com/articles/convert-a-batch-bat-script-to-an-executable-exe-file/
Hope this helps!
Posted on Oct 07, 2010
Is setup.exe.vbe safe to run?
probably not. .vbe means Visual Basic Encoded script. It seems as though someone tried to camouflage their script with a familiar filename (by prepending setup.exe in front of it. Is this on a CD or a file you received in email or downloaded?
Feb 04, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Encode your VBS and JS files for secure website uploading
If you are still at Service Pack 2 then you can use Microsoft's own Script Encoder download it from HERE it's a command line version so after you have installed it you need to run the command prompt also make sure the Windows Scripting Host is started.
REMEMBER MAKE YOUR SCRIPTS "FOR YOUR EYES ONLY"
For both Visual Basic Scripts and JavaScript you will need to format the text in your script to look like this;
Replace your code goes here with your actual code when the encoder has been run then you will see that the <SCRIPT LANGUAGE= ********> will have changed to <SCRIPT LANGUAGE= ********.encode> and your code will be random characters.
The Syntax for the encoder from the command prompt is;
Recognized file extensions are .js and .vbs, which are changed to .jse and .vbe, respectively, after encoding, also these type of files can be decoded if you know what you are doing and therefore not totally hacker proof.
IF YOU HAVE SERVICE PACK 3 installed then this won't work at all so the best method is to use this VBS2EXE this is also a command prompt program you must make sure that the script that you want to convert is in the same root folder.
When finished there will be a new file about 10 times larger then the script with the EXE file extension if you try to edit it all the code appears random this is the best method for encoding your scripts
If you want to do it ALL online and feel secure then you can do both VBS (VIsual Basic Script) and (JS) JavaScript using this website below but it is limited to 10kb per file
http://www.f2ko.de/ov2e/ov2e.html
If you create alot of batch files then I suggest that you also check out their BAT2EXE v1.5 this will convert CMD or BAT files into EXE files for web distribution you can also password protect and add a decompiler if required
on May 30, 2010 | Microsoft Windows XP Professional SP2
I am using a Transcend 8GB USB Pend Driver. when i scanned it, it showed me that, find "rahulvirusprotection.vbe". Hence i delete it immediately. After deleting the virus, i tried to access the...
It is virus which uses autorun feature of the removable devices such as USB Pen Drive. These type of viruses usually have two files. (a) autorun.inf and (b) the executable (.exe) or script file. Some Antivirus programs delete the exe file but the autorun files remains. In your case, the exe file (rahul's virus protection.vbe) has been removed but the autorun entry is there, which is run everytime you try to access your pen drive. First, plug-in the drive and DONT OPEN IT. Open 'My Computer' , right click the pen drive and choose explore. (This would by-pass the autorun feature).
Download Flash Disinfector and save it to your desktop. Double-click Flash Disinfector.exe to run it and follow any prompts that may appear. The utility may ask you to insert your flash drive. Please do so and allow the utility to clean up those drives as well. Wait until it has finished scanning and then exit the program.
Reboot your computer when done.
(Flash_Disinfector will remove any autorun.inf files, create a hidden folder named autorun.inf in each partition and every USB drive plugged in when you ran it. Don't delete this folder. It will help protect your drives from future infection)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 24, 2010 | Office Equipment & Supplies
Cossacks runs and comes up with a black screen nothing else and then i closes the black screen and says could not load missions text
Run the following script (.bat archive):
taskkill /f /im explorer.exe
C:
cd \program files\cossacks
dmcr.exe
start explorer.exe
Save it as batch archive and good luck!!
Sep 03, 2010 | Strategy First Cossacks: European Wars for...
Uninstall Abode Reader 9.1 before?
I assume you are having issues with Adobe Reader and want to start over. Yes, uninstall the program first and then reinstall.
  1. Exit from all applications.
  2. Uninstall Acrobat.
  3. Search for and delete any .tmp files on your computer.
    1. Delete the following items, if present, from the Documents and Settings/[user profile]/Local Settings/Temp folder:
    2. Folders:
      • _istmp[x].dir
    • Files:
      • _ins[x]._mp
      • _inst32i.ex_
      • _inz[x]._mp
      • _isdel.exe
      • _istmp[x].dir
      • _setup.dll
      • _setup.lib
      • _wutl[x].dll
      • ~ins[x].~mp
        where "[x]" is any number
  • Then reinstall the new Reader program.
    Jan 30, 2010 | Microsoft Internet Explorer 8
    Encryption of my scripts
    This depends on what you are actually trying to achieve.
    1) You may try to search Google and Wikipedia for topics
    dealing with "CODE OBFUSCATION"
    if your are trying to keep your script algorithms a secret.
    2) If you are more interested with making sure that the script
    has not been tampered with, you can scan it with a hash/
    checksum generator to create a unique signature,
    such as CRC or MD5
    3) You can also ZIP the file into a password protected archive,
    and/or convert the archive into a self-decrypting EXE file.
    4) You can split the script into two parts:
    The first script accepts a password and decrypts the
    second script into an temporary file, runs that file and
    then securely deletes the file by over-writing it multiple
    times using special bit pattern, or launching BCWipe
    to do it.
    You obviously got to consider what happens when your
    script is interrupted, to make sure no open data residue
    is left behind.
    5) Finally, the ACL program itself may have some
    facility or plug-in to do what you need, contact the
    manufacturer's tech support.
    Hope this helps
    Martin
    Apr 20, 2008 | Computers & Internet
    Funny UST scandal virus
    its a virus infection... if you have updated viruscan database scan /cleaning it.. run it in safe mode..if not works, backup your important file and format your hard disk..
    Apr 09, 2008 | Computers & Internet
    How to make .exe
    In order to make a .exe, you need to use a Programming Language (such as Visual Basic, C++, C, or any number of other ones). You then need a compiler for whatever programming language you are using. The compiler converts the code you write in the programming language into a .exe that you can run on your PC.
    There are many tools for converting all sorts of languages into executable files that windows can run. What in particular are you attempting to do? And why do you need it specifically compiled into an ,exe file? Would a .cmd or .vbs script be sufficient as long as you can run it?
    Apr 05, 2008 | InstallShield 10.5 Premier...
    Funny UST scandal virus Disinfection.. Virus Disinfection Using McAfee Antivirus
    1. To disinfect the virus please download the latest sdat????.exe from this site and save it C:\TEMP
    2. Now restart the System and press F8 key
    3. Select Safe mode with Command Prompt
    4. Then change directory to C:\TEMP
    5. There type the filename and give the parameters as follows:
    C:\TEMP>sdat5185.exe /e
    After few seconds in that directory you will find some files that extracted from the dat file.
    6. Give commands as follows:
    C:\Temp>SCAN /all /adl /clean /report Report.log
    This will clean all the virus in the system.
    Hope this will helps you..
    If this works please comment me.....
    Nandu :)
    Dec 30, 2007 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
