Question about Briel Java CG5 Electric Burr Grinder
I need an instuction manual for the Briel java grinder
I need instuction manual for a Milwaukee sander/grinder
go to milwaukeetool.com and you can download the owners manual, you will need the serial number to ensure that you get the right one. Let me know if you need more assistance
Sep 23, 2011 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
Tip
Briel Java coffee grinder doser failure
My doser lever failed. I diassembled the doser housing (three screws in the base) and found the return spring had fractured. I did not have any spring steel (such as a piece of clock spring) so I found it possible to cut a piece out of an old feeler gauge (38 thou) using tinsnips. I cut to the correct length and glued into the plastic housing as originally -just saved myself $100 and more importantly to me, all the pain of getting the grind setting correct on a replacement grinder
on Jul 22, 2008 | Briel CG5B Electric Burr Grinder
Hello. I am looking for a resevoir that the coffee grinds go into for a Briel CG-5
My doser lever failed. I diassembled the doser housing (three screws in the base) and found the return spring had fractured. I did not have any spring steel (such as a piece of clock spring) so I found it possible to cut a piece out of an old feeler gauge (38 thou) using tinsnips. I cut to the correct length and glued into the plastic housing as originally -just saved myself $100 and more importantly to me, all the pain of getting the grind setting correct on a replacement grinder. You can also buy from Portugal Anabela Maia de Sousa After Sales Services Briel - Industria de Electrodomesticos, S.A. Rua Sidonio Pais, 390 - Lugar do Rio 4475-498 Nogueira da Maia - Portugal anabela@briel.pt www.briel.pt
Tel: +351 22 961 9430 Fax: +351 22 961 9435
Nov 23, 2009 | Briel Coffee Makers & Espresso Machines
How do I use the Briel eg82, where do I get a manual?
Hi.
Briel is the Portuguese leader in building espreso machines and small appliances.
Briel had opened only recently to the international market. Their manuals are not available for download, and many models do not have an English manual available.
Check if a manual for Eg-82 is available by using this online form to contact Briel.
Regards.
Nov 17, 2009 | Briel Portofino EG-82 Espresso Machine
How can I get an Instruction Manual
Contact the manufacturer (Briel) about that one. They don't seem to have manuals on their website ( www.briel.pt ), and their customer service number is in Portugal, so I would recommend sending them an email to request a manual - their email is geral@briel.pt
Good luck! :)
Aug 25, 2009 | Briel Vilamoura ES-16PG Espresso Machine
Need new reservoir
You can contact Briel direct they will supply spares but only from Portugal (I am in UK no one held spares) Email customer service Remember post costs could be high so consider replacing the Briel locally as it is obsolete and although a good entry level grinder, far better ones can be obtained and after all grind consistency is everything. If it is just the return spring see my FixYa. Address below Anabela Maia de SousaAfter Sales ServicesBriel - Industria de Electrodomesticos, S.A.Rua Sidonio Pais, 390 - Lugar do Rio4475-498 Nogueira da Maia - Portugalanabela@briel.ptwww.briel.ptTel: +351 22 961 9430Fax: +351 22 961 9435
Jul 27, 2009 | Briel CG5B Electric Burr Grinder
Briel Chamonix es35 New..
Pods are expensive. I buy espresso grind from my favorite local espresso shack and I take regular drip coffee filters and cut small discs from them to put in the bottom of the cup that holds the grounds (moisten first). It works great and keeps the finer grounds from clogging it up.
Feb 21, 2009 | Briel Chamonix ES-35 Espresso Machine
Briel chamonix instructions
I work at Briel USA. Please send your email address to me requesting a manual for a Chamonix and I will send you one via pdf.
irene@smithagy.net office phone 770-509-3006
Also,you might find what you need at the Briel USA website at: www.smithagy.net click Briel.
Please let me know if you need anything else.
Thank you.
Best Regards,
Irene
May 29, 2008 | Briel Chamonix ES-35 Espresso Machine
Need to find replacement parts for Briel Chamonix
HI,
You can order any Briel part you need at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
info@electra-craft.com
thank you.
May 05, 2008 | Briel Chamonix ES-35 Espresso Machine
Briel Java CG5 Electric Burr Grinder Logo
115 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Dennis Fitzsimmons
Level 1 Expert
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
