Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
MY ULTRASHARP HAS SLIGHT GHOSTING AN EIGTH OF AN INCH TO THE RIGHT OF ANY THING ON THE SCREEN. IT IS 18 MOS OLD. IS IT FINISHED ?
    Sergeant:
    Champion:
  • 253 Answers
It is going out yes needs repair
Posted on Oct 07, 2010
Hitachi 50v500, we just put in a new lamp, now the picture on the screen is slightly doubled, what do I do?
Here is what I suggest----look at lettering and or put the mode to 4X3 which is smaller left and right.
Look at the edges of that picture or lettering on screen---this model sometimes has a ghosting where images have a slight shadow, like with rabbit ears.
If this is the case there is a way with the remote to CORRECT IT.
I have the information--confirm if slight ghosting around letters--it can be white or any color.
I have seen this before.
SD TECH
Sep 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
The monitor connected to a docking station will not resize after using laptop with an InFocus projector
The inFocus projectors typically force a lower screen resolution - you have to go back and reset the monitor to it's proper resolution. Only takes a few seconds - go onto a blank area of your desktop, right click, select properties, settings, then adjust the resolution. Hope that helps - I've had the same thing happen when using a projector, and have never been able to have the screen automagically "readjust" after using the projector...
May 19, 2009 | Dell 2007FPW UltraSharp 2007FP 20.1-inch...
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
My screen is x X y inches. The windows page doesnt fit into it. There is one inch of black space on the monitor on the left and one inch of my windows screen is lost on the right!!!!!!!
With the on-screen controls, select Auto-Adjust. This should set suitable defaults based on the incoming signal. If you are using the VGA connector and the position still needs to be adjusted, use the on-screen controls to shift the displayed image to the proper location (under Display Settings -> Horizontal Position).
Apr 17, 2009 | Dell UltraSharp 1908WFP 19inch Black...
Ghosting and blue tinge on close up on people
It is fixable depending upon the make and model.
Mar 28, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Red ghosting
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unusable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Oct 31, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Unit 8 mos. old and now makes loud, awful noise
you have had the thing for 8 mos try cleaning the hepa filter with a vacuum use the brush type attchment or u might have defective filters go to kaz.com or contact honeywell
Jun 24, 2008 | Honeywell HHT-081 Air Purifier
Ghosting
Does the monitor do this on all resolutions?
Try changing the refresh rate on the monitor's properties page and see if the effect changes at all.
Feb 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
56 people viewed this question
Alun Cox
