Question about Sony KDF46E2000 46" Projection HDTV
I replaced the lamp on my Sony TV because it said that it was nearing the end of its life, but now I still have the message that says the bulb is nearing the end of its life.
    Sergeant:
    Champion:
  • 253 Answers
Reset it should be something in the manual that tells you how to reset the defaults on TV.
Posted on Oct 07, 2010
  • 4234 Answers
SOURCE: Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Posted on Mar 09, 2009
  • 116 Answers
SOURCE: How long do we have to replace the bulb when we
I would say this is the time you should place an order for a new one. if you already have one then you should replace it immediatelely. characteristics of lamps chage drastically during the end of their lifetime and this can have diverse effects ranging from degraded picture quality to damage to the circuit arising out of catastrophic failure of the lamp. Yes i advise that you replace the lamp at the earliest possible opportunity.
Posted on Oct 24, 2009
  • 1015 Answers
SOURCE: sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Posted on Jan 09, 2010
milkburp
  • 416 Answers
SOURCE: Just replaced the projection lamp but the tv still
Use the "Lamp Replacement" option in the Setup menu to reset the timer.
Posted on Mar 13, 2010
  • 160 Answers
SOURCE: replaced the lamp on my sony tv but it still says
Hello.
Lamp timer have to be reset in service menu of your TV. Without resetting it you will have this message every time you turn TV on.
I can not provide you with directions how to do it - it's forbidden by Sony for me to give information like this to the customer, because without proper training you can easy change some settings by accident that would not be restorative after all and it would cost you pretty penny to replace main board that have all memory settings.
I would advise call any local TV repair and ask them to show up and reset timer (shouldn't cost you too much, they don't need to open up TV or anything like it). Or search internet for specific information (but do it on your own risk).
Regards.
Russ.
Posted on Aug 18, 2010
My TV model number KDF 46E2000. I am getting a message in my TV "Projection lamp is nearing end of life. Please replace the lamp" . Please let me know what to do.
replace the bulb if picture is getting dim. the set is programmed to say this ever so many hours. if u got a manual it tells u how to reset this
Feb 15, 2011 | Sony KDF46E2000 46" Projection HDTV
Getting a message that my lamp is nearing the end of it's life. I have 4 questions: 1. How long do you think I have until it will burn out. 2. Is there only 1 bulb/lamp that will need to be replaced. 3....
Hi, my same Sony KDF 50e2000 has been giving me the "proj lamp near end of life" message for approx 6 months-and we watch a lot of tv/play wii. I just ordered a repl lamp on line
Sep 01, 2010 | Sony KDF-50E2000 50" HDTV
Picture is dim very hard to see. Want to know if it is the bulb,maybe power supply,or a possible board???
It is Lamp/ Bulb that is near to end of its life span.
Replace lamp in tv, replacement procedure is written in user manual.
Make sure to buy Sony original lamp for bright picture.
Sep 01, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
What does it mean by projection lamp is nearing end of life? how can i fix this?
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
Mar 17, 2010 | Sony KDF46E2000 46" Projection HDTV
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony projection lamp is nearing end of life
Jan 09, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony KDF-50E2000 50" Lamp replacement
1.you have 10hrs
2.you can find them everywhere try eBay
3. It is easy except one thing you must have the original remote to reset the lamp counter
May 16, 2017 | Sony KDF-50E2000 50" HDTV
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Sony KDF46E2000 46" Projection HDTV Logo
228 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
