Question about Sony TA-FE370 2-Channel Amplifier
Hi, my sony amp ta fe370 has stopped working. It switches on and all the lights come as usual but there is no sound coming out of the speakers. I have tried headphones and there is no sound there either. Any ideas? Thanks
  • 55 Answers
Power Amplifier Failed, Safty is on to protect your speakers from DC voltages
Posted on Oct 08, 2010
Hi, my sony ta-fe370 has stopped working. All fuses seem fine and there is no obvious visual problems inside. The red led next to the power button comes on but then goes out again. The source selection...
What power are you meaning that Also, all of the other decks connected to this also have lost power Is this mains power If so check the power on the switch
Oct 12, 2013 | Sony TA-FE370 2-Channel Amplifier
Wires connect stereo speaker
It all depends what connections you have on the back of your TV? You should look to see if there are two red and white audio "out" sockets. Don't try to connect via audio "in". If you have an HDMI connection on both TV and amp that will also do the trick. Also SCART sockets have audio out connections. You can get adapter leads to connect it all up.
Aug 19, 2013 | Sony TA-FE370 2-Channel Amplifier
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
Hi there i have this amp it powers up but no sound what could it be thanks
Is there a tape monitor function on the amp? If so, is it off?
Have you tried headphones?
Aug 06, 2010 | Sony TA-FE370 2-Channel Amplifier
No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
Hi I have got a sony TAFE 370 amplifier which does not produce any output, i have tried different input devices and also checked speaker wiring and the speaker selection is on i used it a day ago and all...
If you can't hear any sound from the headphone output, and by sound I mean a hum with the volume turned up, then the amp has either got a faulty internal power supply or the main amp has failed. Try looking inside to see if any fuse has blown. Also look around to see if you can see or smell anything has blown.
Sep 24, 2009 | Sony TA-FE370 2-Channel Amplifier
HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Jan 22, 2009 | Sony TA-FE370 2-Channel Amplifier
I have a Sony TA-FE370 amp. which I have sold and delivered by parcel force. The purchaser reports that after 5 mins. the case became hot and there was a burning smell. Can you geve me any idea why...
Usually that means that the amp was qworking too hard. Have the customer check to be sure that the wires to the speakers are not touching. Also, be sure that the rated impedence for the speakers matches what is required for the amp. If the speakers are rated at 4 ohms and the amp is expecting 8, this will occur as well.
Keep us posted.
Dan
Dec 19, 2008 | Audio Players & Recorders
Sony TA-540E TWIN DRIVE AMPLIFIER
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
Mar 22, 2008 | Sony TA-FE370 2-Channel Amplifier
Sony TA-FE370 2-Channel Amplifier Logo
421 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
