Question about Apex Digital AVL2776 27 in. HD-Ready LCD Television
Appex AVL2776 Need Help !My daughter has a Appex AVL2776. When the tv is turned on there is sound but no picture.Is there something I can fix myself ?
  • qth2masscot Jan 19, 2009
    I have an APEX-3076. I turn it on and the screen blinks quickly and then darkens. I can hear sound but no picture, I turn off set, disconnect power, reconnect cord turn on & cycle through "INPUTS" as directed by owner manual. This use to solve the problem. But it does no good now. I think the power/supply converter has gone bad. I think I can replace it if I can find one.
I have the same problem with this tv and what helped was not to have any other electrical goods pluged into the same plug socket, it didnt cure the problem but t can work for two weeks to a month before the problem appears again, then i unplug it and leave for about five to ten minuits and plug it in again. Although you could try a surge protector this works, ithink that itsw power problem and this tv likes an unintrupted
Posted on Dec 30, 2008
Unfortunately, manufacturer parts and service are no longer available for this television. An eBay search turns up parts for this television, but those parts are quite expensive. If you know what part is bad, you could get it fixed for $100 or more.
I know people aren't made of money, but today's (Feb 2009) 26" LCD televisions can be bought for $300. You can possibly offset some of the cost by selling the parts - people seem to need them.
Spending money to fix this television is risky. A new television will have a warranty (plus an extended warranty with the right credit card), be of better quality and have manufacturer support. Also, the manufacturer might still support your television a few years down the road.
Knock on wood, my AV2776 has had no issues since I bought it in 2004. I went online to get a users manual and found a lot of disgruntled people because these sets cannot be repaired. At the first sign of problems, I'm going to replace it.
Posted on Feb 21, 2009
I have sound but no picture.. had this problem before a yr ago cost me $350. to fix it forgot what they said was wrong but i like the tv so would like to fix it myself or??
same problem with mine its not something you can fix yourself you must sent it back im sorry. since isignia is a best buy only product the fix should be still under warrenty (worked at best buy we warrent the fix for a year if the same problem results we fix it again for free)
Mar 16, 2011 | Insignia 42" LCD Flat-Panel HDTV
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
When hooked directly to cable, I get a blue screen and sound. When hooked to Componet Video, S- Video, or Composit Video via a cable box, I get a picture and sound. Apex remote will not change sound or...
your cable box rf pass through may be turned off if you can access the menu of the cable box by turning it off and hittiing th emenu button on the cable box with tv on an scroll down to rf out if you need hael call your local cable company
Nov 19, 2009 | Apex Digital AVL2776 27 in. HD-Ready LCD...
When i turn on the tv it flashes blue screen quickly then turns black you can hear sound also if I disconnect the power source sometimes that works but then goes back to the same problem the next time I...
I was hoping that fix ya would be a source that I could get parts for the problem I am having at this point the purchase of an expert is not the solution I was looking for
Sep 20, 2009 | Apex Digital AVL2776 27 in. HD-Ready LCD...
My Mitsubishi VS50501A Rear Projection TV turns on then off!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
Sep 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Goodmans 289NS standby light flashing amber no picture or sound
50% trouble of tv is lose connection so, try to re solder it but be care of short circuit
Sep 28, 2008 | Goodmans 289NS 14" TV
Sound problem
It is really unusual that you retained the picture part after the lightning strike, but what is wrong now is in the audio portion of your tv (obvious). However, if you have not taken the back cover off already it could be as simple as a blown fuse in the low voltage power supply or just blown audio amplifiers due to the sudden voltage and current surge caused by the lightning. The fact that you can get your audio through your surround system kinda narrows it down to the audio amplifier section. Just take the back off and look because those size tvs do not have alot of boards. All in all see if the problem is visually obvious like a fuse, because with out taking actual voltage measurements it could be a couple of boards in there causing the problem. Good luck and let me know. God bless you. Robert
Aug 27, 2008 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Sony Wega wont go on
Hii....
When the " SONY Bliking Codes " generated the circuits self diagnostic to trigger the pulse because some error accure....5 times blinking mean there's something wrong whit RGB level,the level not balance after 2 second due at first time the tv on...the protection circuit will send the error report,the tv will have no picture or sound....you will need to check at M board there's much things you have to do...
Thanks
[Vrya]
Mar 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture / No Sound / No nothing
that sounds like the Hi voltage transformer went bad.. If your a tech simply disconnect the horizontal output transistor and see if thats shorted. If it is then it is for sure the HV transformer. If its not shorted look in the main power supply. Its cost is around 40 bucks or so and the transistor is about 15 to 20 bucks. This entire repair should cost ya around 150 to 175. So if you decide this tv is the one you like then have it fixed. Good Luck
Jun 01, 2006 | Sony KV-36FS100 36" TV
Apex Digital AVL2776 27 in. HD-Ready LCD Television Logo
247 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
