Question about Canon MP640 All-In-One InkJet Printer
My cyan cartridge isn't delivering ink. - Canon MP640 All-In-One InkJet Printer
  • 128 Answers
There is a cleaning utility in the printer properties / maintenance area of your printer driver folder. Try a cleaning first, then a `nozzle check'. If you do not get improvement on each cleaning, Try a new cartridge. If that does not work, you will likely need a new printhead.
Posted on Oct 07, 2010
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Espson Stylus D92 not recognising cartridge change
Do replacement procedure, follow How to.. on status monitor. When asked to replace ink tank, unplug all ink tanks, and plug only cyan ink tank. Next....next.. Finish. See status monitor. Is cyan recognized (Not cross sign)? If yes, repeat procedure, without unplugging, plug others 1 by 1.
If no, check for chip connector (for cyan) at carriage, or try to use another cyan ink tank.
Sep 20, 2009 | Epson Office Equipment & Supplies
Check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ink cartridge cyan is not working
Beside of the color ink there are photocouplers, check them
May 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
Ink cartridge won't click in place
no. the ink has stained the led-control board. If the printer is in warranty call brother. If not, you need a new cartholder as a spare part.
May 03, 2008 | Brother MultiFunction Center MFC-440CN...
Canon MP640 All-In-One InkJet Printer Logo
181 people viewed this question
old marine
old marine
