Question about D-Link DI-604 - 4-Port Broadband Router [ DI-604 ] (109524)
We want to configure the d link switch what will be the default configuration ip and user id password
    President:
  • 2,571 Answers
Http://192.168.0.1
user = admin
Password = none (leave blank)
Posted on Oct 07, 2010
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
I stupidly changed a setting on my router configuration using the ip address in the address bar on my internet page , now i cant access it and change it back , i was trying to change my NAT type to open ,...
Press and hold RESET button for 10 seconds it is in the back side of router. Then all settings defaults. Then need to configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 09, 2011 | D-Link DIR-615 Wireless Router
HOW TO CONFIGURE D-LINK DES1024D TO CONNECT TO INTERNET
You can also configure it with below method.
Jun 01, 2011 | D-Link DES-108 8-Port Ethernet Switch
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
I need to access the d link configuration page. while keeping the internet connected to the router i am plugging a cable to the laptop and to the router and entering 192.168.0.1 an error message is...
Hi tkoleilat
If you want to access the router configuration page, follow the steps mentioned below:
If your IP starts with 192.168.X.X or 198.162.X.X then open internet explorer( http address box) and type 192.168.1.1 or 198.162.1.1 and it will prompt for User ID and password
Default User ID " Admin" or " Administrator"
Default Password " password " or " admin "
This will help you to access router page.
Note: To perform these steps you need to be connected via Wired LAN cable to Laptop and the main internet cable to be connected to router.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | D-Link DIR-600 Router
What settings should i configure for networking?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Enable DHCP in router. If you want to create network with router then connect ethernet cable from computer to router or put switch between router and computer. Then set tcp- ip property of lan to ip get automatic so it will get ip from router. Then o Let me know if you need further assistance. Thanks for using FixYa.
Oct 12, 2010 | Computers & Internet
Need modem reset - unable to access using original user ID and password.
Press RESET button for 10 seconds it is in back side of router then all settings defaults.Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 10, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Not able to access it with the default ip address in oder to configure it.
Press RESET button for 10 seconds it is in back side of router then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 06, 2010 | EnGenius Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
