Question about Video Game Consoles & Games
My xbox360 has two flashing red lights on around the power button and hasnt worked for two days?
  • 43 Answers
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
I have an xbox360 and it freezes after 10 seconds of being swiched on it hasnt got the ring of death please help
First, try taking out your hard drive and see if it will play a game then. If that doesn't work, then its likely to red light soon. If you eventually get three red lights, the x-clamp fix usually works.
Mar 29, 2010 | Microsoft Xbox 360 Console
I have 3 flashing red lights on the console and a yellow light on the power supply
3 red flashing lights is known as the red ring of death. Your power supply showing a yellow light is ok, that just means that your power supply is on standby. The first thing you should do is check with microsoft to see if your unit is still under warranty with this site: http://support.xbox.com/support/en/us/xbox360/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnoses on your unit(excluding shipping), and will call with an estimate before any work is done on the unit. All our work is covered by a 90 day warranty, and you can buy up to 4 years worth of warranty coverage.
Nov 16, 2009 | Microsoft Xbox 360 Console
My xbox360 has a red circle instead of a green circle theirfore will not work what can this be
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death"), represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off.
This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console.
Distinct from the General Hardware Failure is a similar-looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error. Two red lights appear when the system is overheated.
Oct 06, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Dead Packard Bell Easynote SJ51, won't power up
Try to reset CMOS sometimes BIOS saves incorrect parameter (especially when overclocking) It must have 3v clockstyle battery into motherboard. If you arent familiar to disassambling and then assambling laptops it will be better do this someone experienced. Take it off 10 minutes to reset CMOS and then return back. Take off ram clean its gilden pins vith dry clothes or naplin and put back.
Jul 29, 2009 | Computers & Internet
XBOX360 RED LIGHTS FLASH ON CONSOLE AND I GET NO PICTURE?
this problem occurs:
  • When there is too much current.
  • When the voltage is too high.
  • When the temperature of the power supply is too high
  • if you have the console plugged into an extension lead try plugging directly into the wall, but 1st, turn off your console and leave power plugged in to allow fans to continue cooling the system.. after fans switch off, carefully plug out power cord and allow cord and console to cool in a well ventilated area for 24 hours. if its still red you may need to replace your power cord as it may have overheated
    Apr 02, 2009 | Video Game Consoles & Games
    When i turn on the xbox360 three red lights come on around the on button
    if its three lights with the right upper quadrant not lit then you have the RROD..red ring of death..call microsoft and get the console replaced..i had three consoles replaced..before calling them do check if the cables are properly connected..questions which customer care asked me where: what is the light status on the power brick?green...is the power cord directly connected to the mains?yes..have you modified the system?no
    i got mine within 4 days.eeb0cb0.jpg this is the image of the infamous RROD!hope it helps..
    Oct 29, 2008 | Computers & Internet
    My xbox 360 not on ,its flash red light
    http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
    Dec 17, 2007 | Microsoft Xbox 360 Console
    Xbox 360 3 red red lights
    1-800-4-MY-XBOX (1-800-469-9269) If you did not open your box an break the microsoft seal. They fix for free. If not you can replace the x-clamp on the motherboard for the GPU. You see the xbox360s motherboard warps because it runs so hot and the cheap x-clamps used to hold down the heat sinks are not strong enough to keep the board straight. When the board warps it losens the solder around the GPU causing the 3ROD. Just google the xbox360 x-clamp mod to find out how to get it done. If you fix yourself it will cost you like $3.00 for parts at Lowes!
    Sep 23, 2007 | Microsoft Xbox 360 Console
    Video Game Consoles & Games Logo
    46 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
