SOURCE: Replaced IC chips and fried something
1)WHICH chips?? 2)Which resistors? (locations) 3)It is worth it. 4)Possible,but usually not needed.
SOURCE: TV Shuts off by iself!
Don't feel bad about Mits. All the projection companies and all
the new TVs have markedly poorer reliability than the good old CRT
types. You should see all the class action lawsuits against even
some of the best companies!
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed
short overloading the supply. They dry
out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
SOURCE: motherboard failures. 4 times in 2+ years.
No Offense rebeleyes1, but they are not looking for an explanation of what most people think. Maybe an e-machine was something perfectly fitted to their budget. Anyways..
Sy ellin, Ive just done about 2 hours of research and what Ive found, honestly, You might not like it. A bunch of other computer technicans curse your board and a couple other boards by MSI. The problem is unknown, some people claim their PCI-E slot just stops working (the slot on the mainboard where you can install a video card). Others claim if you do a BIOS update it might help the problem before it happends. This is quiet interesting to me because I have the same chipset on my mainboard, The Nvidia 6100. My Video card just went poof...So, You and I just might have found the problem. The best thing I can suggest is replace the mainboard in your computer. ASrock mainboards are good, reliable, and cheap. If there is anything else I can help you with, dont hesitate to ask.
Chipset - Provides the CPU functions for a computer.
CPU - Processor Chip
BIOS - Electronic set of Instructions that a computer uses to successfully start operating.
i had just solved this problem yesterday, there
this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on
motherboard EPU
asp0800 near the CPU Socket
2.Press the IC with finger,at the
same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side
surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please
rechecked step 4
