Question about Bose Wave Radio
Setting time need to set the time from 24hrs to 12 hours thank you
  • 1 more comment
  • dcooper963 Jul 05, 2008
    Need to know how to set Bose Wave Radio clock from 24 hour mode to 12 hour mode.
  • artschulte Jul 30, 2008
    I have a BOSE CD Radio, the time is set for 24 hour military time and originally it was on 12 hour, how do I reset it back to 12 hour time???
  • miss6175 Jan 06, 2009
    this is annoying. unplugging it doesn't work. my cat sat on the top of the radio and she never told me how she switched it from 12 hour in the first place. I like dogs much better.
On first generation Bose, press "Alarm Setup" and "on/off" button to toggle between military and 12 our time.
Older model documentation:
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf
Posted on Jan 13, 2009
The date and day are incorrect on my dakota atomic watch; how do I reset these please ?
if just time is off by one to three hour(s) , you need to ck your time zone settings , if the day is off by one day you need to wait 24hrs keeping watch in a good view of the sky (not locked in a metal box) it should auto correct itself to proper day when it receives the radio signal for two time cycles (24hrs)
Dec 13, 2016 | Dakota Watches
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
Nov 05, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I cannot get my ihome ip11 model out of military time. Help. Thanks for any help you can give
Hello pac31:
For 12 hour time format setting: Press the Alarm Ser Button durin time setting to set 12-hour 24-hour display format. Remember to set the correct AM or PM time (an icon to the right of the time display is the PM indicator ther is no AM indicator).
Remember to click the thumbs up if this helps.
Sincerely, Peter
Mar 02, 2011 | Audio Players & Recorders
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Timex 1440 Nylon watch
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
Jul 02, 2008 | HTC Touch Dual Slider Smartphone
Bose Wave Radio Logo
366 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
