Question about Dell Inspiron 1525 Notebook
The LCD on my laptop has gone out. I am having to use my desktop moniter plugged into my laptop to work. How can I find a replacement top screen for a DELL INSPIRON 1525
  • 2,567 Answers
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
As for the replacement, you can search for it using the laptop model on ebay.com
Posted on Oct 07, 2010
BLANK LED SCREEN ON STENTURA 8000
plug in a moniter if you get a picture the screen has gone ,new screen or use with moniter
Nov 13, 2013 | Computers & Internet
Technika white screen lcd
Hi
to test if the lcd screen is faulty or if its the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if the 2nd monitor is also black your inverter needs to be repalced
aries
Oct 19, 2013 | Computers & Internet
My screen went out. Does this model have a replaceable backlight or must I replace the entire moniter?
Laptops have a replaceable LCD screen which is quite simple to replace, but are you sure the screen has gone out or is it the video card? I would start by plugging into an external monitor and see if the display shows on it before condeming the lcd display.
Oct 08, 2012 | Dell Studio 15 Laptop
When my computer is on the moniter is blank.
The monitor only has one cable and it is keyed to fit one way. They are always located under the top bezel. Should have roughly 20 pins and the wire will flow up into the display. If the screen is very very dim (look carefully) then your inverter board is most likely bad these run 40-120 dollars depending on model and are located along the bottom edge of the display itself. If the screen is completely black, try plugging an external monitor into your laptop (make sure you try toggling the display mode) [typically Fn + F7 or whichever says LCD or has a monitor icon.] If the external monitor works then your screen is most likely the problem and will need to be replaced. If the monitor does not work, the motherboard needs to be replaced. You will be hard pressed to find any schematics for motherboards but you could dis assembly the the laptop and easily check for descended capacitors, burns and the light though most of the time I doubt you will be able to see the damage.
Best of Luck
Jan 24, 2012 | Computers & Internet
Screen is blank when turned on but works with external moniter
Probably, the "LCD inverter" has failed -- take the laptop into a dark room -- do you see a FAINT image of your "Windows desktop"?
If so, it's a $20 part to replace, but rent a qualified technician (1 hour @ $60/hour) to safely and properly replace the inverter.
Or, spend $200 to replace the LCD (plus $60 "labour").
Feb 03, 2010 | Office Equipment & Supplies
Moniter's display related problem
Its LCD problem. Its unrepairable. This happen when unbearable weight has placed on laptop LCD or mishandling of the laptop. Better to ignore it or replace your LCD.
Regards;
Hassan
Jul 25, 2009 | Lenovo ThinkPad T500
Laptop screen
Have you tried hooking up an external moniter? If so do you have video on that moniter? If you do have video on the external moniter then you most likely have a bad inverter or a bad lcd panel.I would replace the inverter first because it's not very expensive.If that doesn't work then you can replace the lcd panelAnd if that doesn't work you have problems at the system board level.
Dec 15, 2008 | Compaq Presario M2000 Notebook
Gsteway notebook Screen does not stay on can plug laptop into another monitor and it works fine.
get the LCD on your Gateway system replaced or repaired
contact a local technician
as you are getting display on an external monitor so it makes sure that the screen on your laptop has gone bad.
Jun 18, 2008 | Gateway Computers & Internet
Moniter is black
hi sounds like you need to replace the lcd backlight which lights up your cd display when it goes you can still see things but it's very dim if you need help ordering that part let me know and i'll find you the product code hope this helps
Aug 08, 2007 | Balance CN6555 Notebook
Dell Inspiron 1525 Notebook Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
