Question about Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player
When i turn on my car (vauhxall corsa) i am able to programme radio channels to the buttons, however when i remove the keys from the car i loose all power to the radio and also when turn back on i loose the programmed channels, can you help?
    Novelist:
  • 142 Answers
There's a wire on the radio that connects to a constantly LIVE 12V circuit. This wire usually has an inline fuse. If this wire has become disconnected, or if the fuse blew, or if the fuse supplying the area that this wire is connected to has blown, you'll lose all memory capability on the radio.
Check the fuses in your car's fuseblock for a blown fuse. If you can't find anything blown, check the inline fuse described earlier. My guess is that you'll find one of these is causing the problem.
Let me know what happens. Please rate accordingly.
Posted on May 29, 2008
Opel Corsa will not start intermittently
Sounds like a loose battery terminal I'd look at this then connection to starter motor it sound like a fault from one of these
Apr 18, 2014 | 2004 Opel Corsa
Manuals for spirit su42 and are they programmable and can you update them ///???
Looked and we do not have a manual for the SU42. This radio is not programmable and is not narrowband capable. It was produced with two channels: Ch1 454.500 (Brown Dot) and Ch2 464.550 (Yellow Dot). It also has 32 possible PL codes. You can see the current PL code by depressing the PL button for 1 second after turning on the radio.
Best regards.
May 20, 2013 | Motorola Walkie Talkie 2-Way Radio
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
Vauxhall corsa says SAFE how do i unlock please
Here is how you unlock it:
1) Turn radio off
2) Start engine
3) Press and hold down AS button
4) Turn On radio WHILE holding down the AS button until there is a beep
5) Dial the code using the 1, 2, 3, 4 keys (eg: 1234 would be 1 once, 2 twice, 3 three times and 4 four times)
6) Press and hold AS button for approx 5 seconds
Mar 02, 2011 | Car Audio & Video
I have a radio shack hyperscan 200 channel pro-2039 programmable scanner. How do I erase ALL the stored frequencies so I can start over again?
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Oct 05, 2010 | Radio Shack Radio Communications
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Apr 29, 2009 | Car Audio & Video
Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Mar 24, 2009 | Radio Communications
Can't Switch Frequencies
Your radio needs to be programmed to match the radios at work. Currently your channel 3 frequency is the same as work, but your code on channel 3 is not. Here is a step by step explanation:
1) Turn on the WORK radio, watch the upper right corner of the screen. It will flash the frequency number, followed by the code number. Note these numbers.
2) Put your radio in programming mode by turning on the radio while holding down the PTT and MON buttons. Continue to hold these buttons until the 'noise' stops.
3) Press the MENU button once. Now, using the + or - buttons choose the frequency number.
4) Press the MENU button to lock in your frequency. This will take you to your CODE. Press the + or - button to choose your CODE.
5) Press your MENU button to lock in your CODE.
6) At this point you can walk through the rest of programming features or simply shut the radio off and begin using it. Note: You will know when you are at the end of the programmable features because it will chirp a different beep than you have been hearing when you've pressed the MENU button to lock in your new setting.
If you need more assistance, give eradiostore a call.
Mar 12, 2009 | Radio Communications
Motorola walkie
With the radio turned off, hold in the PTT and the Monitor button at the same time. Continue to hold these in while turning the radio on. Wait for the radio to finish making sounds before releasing the PTT and monitor button. Then simply press the menu button to walk through programming each of the features. When you have reached the end of the user programmable features you will notice the radio has a different chirp to signal you are done. Then simply turn off the radio to leave programming mode.
Oct 26, 2008 | Motorola Walkie Talkie 2-Way Radio
Tone on channels 5-15
I have worked on the TK 3101's and that tone is when the channel does not have a frequency.
It is a PC programmable radio. I assume you purchased the radio used and the previous owner had channels 5-15 "blank"
I can program it for you if you needed.
Nov 05, 2006 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player Logo
94 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
