Question about Refrigerators
My freezer fan has started making noises but fridge and freezer are working. why is that?
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
