Question about Frigidaire Refrigerators
Freezer not working; refridgerator starting to warm up as well. lights are working
Upper freezer not cold/ ice maker not making ice
Posted on Nov 03, 2008
  • 1462 Answers
SOURCE: freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Posted on Apr 09, 2007
RJTech
  • 32 Answers
SOURCE: kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Posted on Dec 22, 2007
  • 9 Answers
SOURCE: freezer is cold refridgerator is warm
PURCHASE troubleshooting refrigerators at https://www.applianceuniversity.com/store/products/Secrets-of-T%7B47%7DS-Refrigerators-%231009.html
Posted on May 25, 2009
  • 127 Answers
SOURCE: My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Posted on Jul 03, 2009
aasc
  • 1606 Answers
SOURCE: my top freezer refridgerator PTB1953GR freezer
Sounds like the overload/relay plugged onto the compressor is bad . Easily replaceable . Pt # 12002782 . Remove the back panel and disconnect from electrical outlet . On the compressor itself , this piece had 3 wires going to it .
Posted on Aug 30, 2009
The refridgerator and freezer are failing to maintain temperatures. The light for the refridgerator temp. is blinking constantly. Both sides continue to raise in temp. regardless of where the setting is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Refrigerator
heatman101
Jan 16, 2011 | Refrigerators
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Refridgerator/freezer is not working
Sounds as if the compressor is not running even tho the fans are. The overload relays on the side of the compressor are usually the source of this problem. They are on the side of the compressor and if you change these out you should be fine. Fairly easy to do as it should just be a plug connecting it. Hope this helps.
Feb 21, 2010 | Maytag MTB1953HE Top Freezer Refrigerator
Kenmore Freezer works, but refridgerator is warm
Either there is a refrigerant leakage or if it is a no frost refrigerator air ducts to the refrigerator is closed due to frosting. Switch off the refrigerator for 3 hours and restart again.
Aug 15, 2009 | Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Freezer works but refridgerator warm
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
119 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
