Question about Whirlpool MH1170XS Microwave Oven
We have a whirlpool gold above range microwave sn GH4184XSB-1. It started making a high pitch noise when running. Do you have any suggestions on how to make it stop?
jsrock516
  • 5911 Answers
SOURCE: Microwave won't heat/Makes buzzing noise.
The symptoms you are describing are typical of a magnetron that has gone bad. Continuing to attempt to use the oven in its current condition can cause further damage. So, I would recommend not using it. Microwave ovens are considered dangerous and repairs should not be attempted by anyone that is not electronic saavy. The High Voltage Network inside the oven has voltage potentials of 14,000 volts and higher. If you feel this is something you wish to attempt, the Magnetron part number is 1156751 and costs approx. $158. Keep in mind, if the magnetron has been arcing and making a burning smell you may have burned the protective coating that lines the walls of the waveguide. If the waveguide is damaged it is not repairable. I do not know if this is a replaceable item on your model microwave. Double check your warranty information and/or owner's manual. In many cases the magnetron is warranted for several years beyond the limited warranty that comes with most appliances. Post back with comments and let me know if you want me to assist you further. In addition, if you provide me with your EXACT model number (located along the door opening) I can narrow down parts a little better. I know this all sounds discouraging, but I do hope I have been able to help you.
Posted on Jan 15, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My whirlpool gold microwave model
Your thermal overload (thermostat) is bad if the oven powers up when you jump across it.
Are you sure the thermostat is the correct part for your model?
It should be part # 8183703. You can get that here.
Posted on Oct 20, 2008
SOURCE: Whirlpool Gold Microwave Mod#GH7155XHS-1
The push button to open door is broke. Trying to take chasis off but have some funny shape screws preventing me from taking apart. Most of the screws are philips head the funny ones are octagone shape with a point in the middle. How can I get these off?
Posted on Feb 13, 2009
breddi2
  • 126 Answers
SOURCE: Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Posted on Apr 26, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave timer counts down but doesn't turn on when started
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Aug 30, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
What causes a ge spacemaker above the range microwave to quit heating and makes a deeper pitched noise?
This louder, 60 cycle hum is usually caused by a bad magnetron. The unit will not heat when this happens. Repair cost can exceed $100.
Dec 29, 2017 | GE Spacemaker JVM1540 Microwave Oven
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
We have a MH6110XEQ-1 850 Watt built in microwave (manufactured in 1998). I put something in, entered 1 minute, hit start and before the motor engaged everything went "off". Can you suggest a...
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
If the magnetron has failed it is possible that it has taken out the mains fuse. Replace all faulty components with identical types and values!
Hope that helps.
Nov 12, 2010 | Whirlpool MH7155XM Microwave Oven
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Microwave is 21 years old. It is above the range
Um, no. You can get a new microwave that is much, much more efficient for a fraction of the repair cost.
Nov 09, 2009 | Whirlpool MH7135XE Microwave Oven
My whirlpool gold microwave model GH4184XSB-1 stopped working after a paper plate caught fire inside. I replaced the wiring going to the thermal overload and the thermal overload but it still doesn't work...
Oct 13, 2008 | Whirlpool Microwave Ovens
Whirlpool microwave mh6150xls makes noise while running
The oven may not be seated properly. check the bushes at the bottom.
Apr 07, 2008 | Whirlpool MH6150XMS Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
135 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
