Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
Can you use Handy Master Fire Fan Heater Md#HMF 13 inside?
    Problem Solver:
  • 8 Answers
Yes,i have the same one.just make sure it is not pointing at anything an keep it in the center of the room.do not use it as a substitue for your normal hous heating system.
Posted on Oct 08, 2010
Pool heater
hi please try to reset the circuit board, by turning the heater on/off from electric power, if don't work you got to replace the water temp sensor located inside the circuit board (BROWN WIRES) if still display the same problem try new circuit board.for this type the heater a master temp, pcb will work rev.R-13 Good luck. if you need part # let me know, remenber before replace any electronic parts in heater SHUTT THE POWER OFF.
May 04, 2013 | Pool & Spa
How to repair code 13 for tankless water heater
10-15-2012
Code 13 is probably Rheem, Richmond, Ruud, Paloma etc tankless.
Copy following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error 13 is oxygen depletion sensor
Imperfect combustion.
For example if tankless does not have required maintenance, then burner can get dirty and clogged.
This will cause unburned natural gas to rise inside hot flue pipe causing risk of explosion and fire, or in case of propane gas that is heavier than air, the gas will build up inside combustion chamber and cause explosion and fire.
Oct 15, 2012 | Water Heaters
Where are the filters on a Handy master forced air heater- our smells very bad
Pretty much every kerosene heater I've seen has the filters in the same place. You have to take the cover off, then locate the pump at the back of the motor. Take 2 or 4 screws out of the pump to remove the pump cover, and you'll see the filters in there.
There are some kind of generic directions here: http://www.desatech.com/techDocs/Kerosene%20Heater%20Filter%20Replacement.pdf
I'm sure they apply to your heater too.
Be careful putting it back together, it's reeeeally easy to crack the plastic pump by overtightening the screws, and it will never work right again if you do.
Dec 31, 2010 | Master Heaters Master B115DT 115,000BTU...
How do i get an owners manual for a Handy Master kerosene heater (HM19)?
I get about 90% of my manuals from the manufacturers web site. Give that a try. You may have to do a bit of research, I do not recognize the Handy Master brand, it may be a relabel from another manufacturer.
Good Luck
Gilshultz
Dec 02, 2009 | Master Heaters Master B115DT 115,000BTU...
Ac problem
I just fixed mine. same problem, no ac light no fan. inside the heater control assembly there is a electric wiper arm on the fan switch. This arm connects all power for fan and ac. Mine broke out of the fan control switch. Dash is not too much problem to get out. Have to pull top dash center section out by puching forward and lifting out. pull all screws on center dash counsel. remove radio, two side covers that hide screwsand lower trim that holds emergency flasher switch. remove cables from heater control and wires and remove. Took me about an hour. The code on radio will need to be reset so make sure you have that handy. Hope this helps..
Jul 28, 2009 | 1998 Volkswagen Beetle
Sticky fan
remove the outer cover and then the plate at the back of the motor, then lube the back of the motor and the inside of the plate with a lubricant spray. (wd40) put it all back together.
Jan 10, 2009 | Milwaukee Tool Master Heater B200 Series...
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
95 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
