Question about LG Refrigerators
The motor is making a funny noise - LG Refrigerators
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Picasso 2005 axsara doesn't want to start and when I switch a key it makes funny noise instead of starting. And odometer doesn't show any indication its blank? What could be a problem?
You need to elaborate what "funny noise" your car is giving you. Does it try to tell you something ?
When does the "funny noise" appear? When you twist the starting key? If so, I guess it is the starter motor. The relay does not actuate and connect the gears on the starter motor to the gears on the flywheel.
If your battery is empty, you will hear just a short "knocking" from the relay on the starter motor.
Oct 13, 2017 | Cars & Trucks
Replaced beko motor brushes on washing machine and they are making funny noise
Please remove and reset the brushes are it could be out of alignment , Please check this link for tips: Brush setting
Feb 01, 2013 | Washing Machines
Doesn't want to go onto spin cycle just makes funny noises
Possible that there is slippage when the program comes to the spin mode. Please check the drive and see if the belt is slipping or the drive is jammed. If not check the motor drive.
Jan 21, 2013 | Beko Washing Machines
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
Door Locks making funny noise
you need to replace the door lock motors or acutators
Oct 09, 2009 | 2000 Jeep Grand Cherokee
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Washing Machines
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Brand new pump that i bought it from store and i installed myself but it makes a distinctiv noise. emerson 230 v 1 hp.
is it the water going through the wet end or is the motor making the funny sound?
If the motor is sounding funny then you may have a bad motor. if the wet end is sounding really noisy then the motor may not be matching the size of the wet end as far as the HP. make sense? if your motor is bigger than the rating on the wet end it is pushing way too much water it is will be very noisy.
Jan 02, 2009 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Refrigerators Logo
64 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
