Question about Hotpoint HSS25GFP Side by Side Refrigerator
Freezer/fridge not pulling down to temp. compressor is running, coils are free of dirt
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ....
Posted on Oct 08, 2010
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
I have maytag mff2557hes fridge that seems to run more often than not. Freezer and fridge cool fine but it seems to run all the time. Is this normal?
Pull the unit out from the wall and check the coils at the compressor for lint and dirt buildup. The coils and fan should be free of any debris to operate correctly.
Nov 03, 2012 | Maytag MFF2557HES Stainless Steel French...
We have a side by side samsung fridge/freezer. The freezer is working fine but the fridge is up to 60. We pulled the fridge away from the wall and cleaned underneath and also removed the grate in the...
One of the biggest problems is with the new refrigerants (R134A in this case). If the unit gets overheated it actually causes the salts in the moisture releases and travels throughout the system eventually clogging the metering device (capillary tube). The only thing that can be done is to have the system flushed, new drier, evacuated and re-charged.
Then make sure there is enough air circulating and keep the coils squeaky clean.
Nov 29, 2010 | Refrigerators
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Refrig temp not cold enough..drinks are almost warm
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Motor running all the time and what should be the temp inside freezer and refig
freezer 10 degrees or less. fridge 33-40 degrees. Make sure there is good circulation inside and the coil is free of dirt and dust.
Jun 30, 2009 | Refrigerators
Fridge will not pull down to proper temp
check and srr if you have frost build up in freezer
Apr 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag fridge not cold
IF THE COMPRESSOR IS COMING ON AND OFF IN A MATTER OF SECONDS, YOU MAY HAVE A BAD START DEVICE(RELAY) ON THE COMPRESSOR. IF THE COMPRESSOR RUNS FOR FIVE MINUTES OR MORE, CHECK THE FAN NEAR THE COMPRESSOR AND THE COILS
UNDER THE REFRIGERATOR. IF THINGS SEEM EXTREMELY
HOT, CLEAN THE COILS AND MAKE SURE THE FAN IS RUNNING. IF IT IS ALL O.K. YOU MAY HAVE A LEAK IN THE SEALED SYSTEM( TUBING WHERE THE FREON FLOWS).
THAT WOULD REQUIRE A CERTIFIED TECHNICIAN LICENSED TO HANDLE FREON TO MAKE REPAIRS.
Mar 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Sep 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
52 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
