Question about Skull Candy Lowrider Headphones
Got my Skullcandy Lowrider Headphones 2 days ago, fine at the start, but then the music only played in one ear, unless I wiggled the headphone jack about a bit. Today, it got worse, with neither of them playing unless I move the wire jack around. Bit miffed since Only got them recently -_- Anyone have any solutions/ideas? thanks in advance, chris
  • Skull Candy Master
  • 5,126 Answers
I suggest you take them back to the shop and see what they say, hope you kept the recit! Otherwise contact Skullcanday. Don't attemp to fix it yourself or you won't get your money back or any replacement, as you should under law.
Posted on Oct 12, 2010
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
Mar 25, 2011 | Skull Candy Lowrider Headphones
My 30 millimeter jack brock aftrr 3 days! Help!
Skullcandy headphones are infamous for this happening. Luckily, there is a lifetime warranty from the manufacturer. Or, if it's possible, I'd return the product to the place you purchased it to get a replacement.
Mar 06, 2011 | Skull Candy Lowrider Headphones
Wiring diagram for skullcandy headphones
The cat chewed my skullcandy headphone wire in two, how do I splice them. Thank you, Robin
May 17, 2010 | Audio Players & Recorders
Skullcandy lowrider xbox 360 headset microphone not working. I can hear but mic dosen't work
Either it's not plugged in all the way or there is a short in the line somewhere. I would pop the ear cover off to look at the wiring, it could have come unsoldered.
Feb 27, 2010 | Skull Candy Lowrider Headphones
One ear doesn't play while the other plays. Sometimes alternates, and sometimes doesn't sound isn't heard in either. What is wrong?
Check for broken or starting to break wiring either at the jack or at the phones. Here is a link to a repair guide:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Nov 29, 2009 | Skull Candy Lowrider Headphones
I can't seem to hear anything from my left ear in my Skullcandy Lowrider headphones. Is there anyway to get them fixed with out needing to get a new pair as they were a present??
If you have used the headphones a lot then your wires probably broke. I had the same thing happen to me, and also on a pair of expensive sony earphones. So it's not the brand. It just happens over time when use headphones/earphones a lot.
Sep 06, 2009 | Skull Candy Lowrider Headphones
Lowrider 360 Skullcandy Headphones don't seem to work on my xbox.
The thing you need to realize is, the headphones are not defective. Headphones cannot choose to individually make voices/game noises/music louder or quieter. Either they play audio or they dont.
What your issue is, is configuration with the xbox (the soucre FEEDING the headphones) Only there can you choose the amount of voice/game noises/music and their respective levels.
Below is a link that headphone company has on their site for the settings you need to change in your xbox.
http://www.skullcandy.com/manuals-and-drivers.html (see the second section, second option doesn "xbox settings for lowriders")
Any further settings will need to be assisted by an xbox support person.
May 16, 2009 | Skull Candy Lowrider Headphones
Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
May 14, 2009 | Skull Candy Lowrider Headphones
Loose Wire, please help
You will have to buy a replace ment jack and solder the connections. These cords seem to have different colors between manufacturers but start by soldering the green or blue (left) to the tip of the plug, the next ring to the red(right) wire and the base to the copper(ground) wire. Try to get a plug with a metal shield that unscrews and make sure you thread the cable through the shield right way around( threads towards plug before you solder.
Apr 21, 2009 | Skull Candy Lowrider Headphones
My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Feb 23, 2009 | Bose QuietComfort 2 Consumer Headphones
Skull Candy Lowrider Headphones Logo
330 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Owen Barnes
vimal
vimal
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
