Hi, i have a nikkai 7in tft tv, when its on any text on screen is back to front,(the whole picture is back to front) i know its got mirror image facility but dont remember how to correct it.
  • 4 Answers
Menu - system - option 2nd from bottom with rotating arrows rotates and reverses display
Posted on Nov 28, 2010
  • Na3rul Jun 26, 2011
    I need help with my nikkai tv mirror image problem. Please help. Naz
7" Nikkai tft digital tv no signal
Check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 01, 2014 | Televison & Video
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
Shadow on Flat Screen TV
Projection TV correct? This may take some work but it is common for a spec of dust to settle onto the Mirror inside the TV, The back side of the TV screen or onto the Lens from which the Video image is projected. Some TVs have ports that allow you to access the inside of the TV from the side, others you must remove the screen.
This is not something to do every day or every week and it will not improve the picture. You only do this when you notice that it is dirty. Any more than that and you yourself will create a bigger problem. ONLY LIGHTLY DUST the screen. Soaps, water and windex will leave streaks, damage the screen and cause more trouble.
Projection TVs are the eqivalent of a big flashlight showing onto a wall. Put you hand in front of the light and you get a shadow.
Inside you TV there is a light (the TV picture) that bonces of a mirror attached to the inside of the back of the TV. The light reflects off the mirror onto the back of the screen. You view this refelected image from the front. Spiders commonly make webs inside the TV that appear in the picture. Dust Bunnies may get blown into an area and become stuck in the way. Sometimes a lite tap, shake or blow may remove this also.
Dec 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
42" LG RZ42PX11 Plasma - rainbow lines on whole screen but sound
hi there.its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.hope this helps somewhat,regards,steve.
Feb 03, 2008 | Televison & Video
Phillips
Hi. I had the same problem with my Philips RPTV and the fix is extremelly ease. You just need to open the back cover (mine uses torx screws). Inside the tv is very mechanic. You will find the three CRTs and most likely the lenses are dirty. You just need to wipe them off with a soft cloth. Also the CRTs project the image not directly to the screen, but to a big mirror and that mirror will be most likely dirty (like when you open the hot water in front of a mirror). Once you clean the mirror and the crts, your tv will like as the they you got it.
Jan 24, 2008 | Philips 55PP9502 55" Rear Projection...
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 works fine but has hazy picture!
ISCABITTLE-TRY REMOVIG THE WHOLE FRONT SCREEN ASS'Y. AND CLEANING THE SMALL MIRROR INSIDE/BOTTOM YOU'LL SEE A HUGE DIFFERENCE-JOE TV
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Electro Med Services...
