Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
I Have A Cozy Space Heater And It Will Work For Awhile Then Goes Out, Relight The Pilot It Stays On Turn The Heater On And It Will Work Awhile Then It Shuts Off Again
  • 59 Answers
If you have the vent pipe in a chimmney or vented outside wall can cause this problem, need to either put a liner in chimmney or vent insde the room with the heater up thru the ceiling.
Posted on Oct 12, 2010
Where is the pilot light on the cozy w352e heater? the heater went off and does not go back on when i change the thermostat, and i can't see anything lit when i open it up, so i'm assuming i just need to...
Open the lower panel. You will see a valve with a knob marked On Pilot and Off. This is the gas valve. Turn the knob to Pilot. Push in on the knob and if you are in the correct setting, the knob will depress about 1/2" into the valve. Now look for a red button and snap it in much like a gas grill starter. Keep the knob depressed and look into the small viewing port to see if you started the pilot. Hold the knob for 30 seconds then let it out. You should see a blue flame. If you don't , try it again and hold the knob in longer this time. Once you get the pilot to lite, rotate the knob to the On position. If for some reason you can't get the pilot to stay on, you may need to replace the thermocouple. If the pilot won't light at all, you may need to get into the pilot Assembly with a long match or grill lighter and light the pilot.
Nov 30, 2009 | Cozy (W352E) Heater
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Williams Model 435FXR Serial GO222436 Forced air pilot keeps going out
BY THERMISTOR, ARE YOU MEANING THERMOCOUPLE, I.E. WHAT YOUR PILOT LIGHT IS HEATING? IF SO, COULD BE WEAK AND NOT GENERATING ENOUGH VOLTAGE TO STAY OPEN, SHOULD BE BETWEEN 10-25 MILLIVOLTS DC, WHICH CAN BE TESTED AT THE INTERRUPTER LEADS. YOU CAN ALSO BYPASS THE LIMIT DISC TEMPORARILY TO SEE IF THE UNIT STAYS LIT, REPLACE IT IF THE UNIT RUNS.
Jan 28, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Pilot will nost stay lit!
you could be right it could be a dirty pilot remove the pilot assembly and clean it has an orifice inside where the gas has to pass through its about the size of the point of a pin so its possible that its clogged, if this doesnt work the thermocuple might be bad
Jan 01, 2008 | Cozy (W352E) Heater
Cozy heater
Make sure the gas valve is turned to the "On" position after the pilot stays lit. You may need to replace the thermopile. Some units have a thermopile rather than a thermocouple and it will not allow the gas valve to open if not enough voltage is being sent to the gas valve. Hopefully your gas valve is working properly and will not need to be replaced.
Dec 04, 2007 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
169 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
