Question about Acer Aspire 1642WLMi Notebook
Combo drive not working
My combo drive is not reading any cds, dvds, software, mp3, anything?
  • sumrani1 May 29, 2008
    i think the lens doesnt slide up and down. i tried manually moving it but it only showed the files on an audio cd. when i tried playing it no sound came out
    Problem Solver:
  • 19 Answers
When a rom cat read anything then that means maybe the cable is bad,if the cable is good then u can adjust the variable resistor under the lens then if that doesnt work then u can change the rom but i believed that adjusting the lens variable resistor will solve the problem.
Posted on May 29, 2008
    Genius:
  • 2,785 Answers
Plz try cleaning the rom with lens cleaner if the problem persists you can try by changing the datacable,if the problem remains then you have to change the rom
My combo drive is not reading CDs but reading DVDs perfectly
a different laser is used to read CDs than is used to read DVDs. The laser for you CD reader has most likely gone out of alignment. It's time for a drive replacement.
Dec 09, 2010 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
Reads cds and dvds, but won't burn to them
Your drive can only burn CDs, not DVDs. To burn CDs you need to purchase a blank CD-R or CD-RW at a local computer store. You can burn a CD-R only once but a CD-RW can erased and written upon many time.
Try Nero software for burning.
Sep 19, 2009 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Apr 20, 2009 | NEC ND-2500A DVD±RW Burner
DVD drive reads DVDs but not CDs
Sep 28, 2008 | Computers & Internet
DVD NOT READ
if you are good at opening then open the combo drive and clean the lens once by using some lens cleaner solution and then refit it it should work ...
if you still persist the problem then think that the life of the combo drive is getting down and the time to purchase new one is getting nearer ..
after some days your combo drive will fail to read the cds but it will read occasionally for some days after that it will not read anything that s because the lens is becoming weaker ...
at the cost of replacing the lens you can purchase the new dvd writer ...
but also try cleaning the lens with some lens cleaner solution after that it may work for some days ..
the only problem with the combo drive is the lens will be weaker than the normal dvd writer or cd writer so after some days of usage it fails to detect dvds followed by it fails in detecting of cds too ...
thank you
rate my solution
Sep 11, 2008 | Computers & Internet
Need to set up my laptop with DVD RW drive to burn DVD
Yes, you can install the cd with the Nero Software in the new Laptop, and you will be able to write CDs or DVDs, but if you have a combo only you will only be able to write/burn CDs but read DVDs no problem.
ciao Ed.
Dec 10, 2007 | Computers & Internet
Can read cds but not dvds
Try this, but if the problem persists, you need to replace the drive. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers.
Mar 10, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Mar 07, 2007 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Acer Aspire 1642WLMi Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
