Question about Philips Magnavox 27MS343S 27" TV
My phillips 42MF237S/37 just makes clicking sounds when i turn it on.
  • Anonymous Mar 13, 2014
    42mf237s/37 no enciende
Phillips 60pl9220d 37
The power supply may be failing.
Nov 22, 2013 | Office Equipment & Supplies
42MF237S/37 will not turn on
Check and replace its main power regulator board. Check this link for more details.
Apr 03, 2013 | Televison & Video
Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Aug 07, 2009 | Philips 52PFL7422D/37 TV
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Problem
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips Magnavox 27MS343S 27" TV Logo
859 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
