Question about Panasonic PT-52LCX65 44" HDTV
Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides with a bulb replacement message from the television set. I was thinking about ordering a new bulb. If that doesn't work I will be thankful that I purchased an extended warranty on this product! Any suggestions?
  • mgrant116 Jun 04, 2008
    Replaced with "new" lamp! spots persist. Now it's time to use the warranty. thanks for the assist.
Repair Bulletin #200801001 posted 6/23
Call Panasonic and ask for free repair if you have this problem
Posted on Jun 06, 2008
  • 4,234 Answers
Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
Keep us posted.
Dan
Posted on May 29, 2008
  • ABRsvcs Jun 04, 2008
    The spots are now likely in the optical engine. The light and heat from the bulb can damage some of the filters inside. This is normal, although I wouldn't have expected it quite so soon.
    Keep us posted.
    Dan
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Yellow spot on sony tv screen
not much you can to it sounds like some magnetic force was next to it IE speakers
Aug 18, 2012 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow spot on Sony 55"
Possible dust in light engine? What ever you do, don't blow it out with the set on or hot. This easily equals instant death to bulb.
Apr 23, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
PT 44 LCX 65 Panasonic Red spot upper rt quadrant of screen
This is a FIRMWARE problem. do not let someone replace any parts in your TV.
I had a repair guy come out with a small computer and he took the back off of my tv, plugged in the computer and the red dot slowly began to disappear.
this was in March 08, no problems since
Dec 18, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Screen spot
Since you have a black spot,you need to look at the mirror or inside screen. If it were a certain color, like purple or yellow, for instance, I would suggest a lens or picture tube, but, since it is black in one spot, I would suspect debris in those areas.
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Yellow spots
I have no suggestions but I am having the exact problem, yellow haze in the top right corner of the screen with a yellow line running down to the bottom of the screen. I guess we need to call tech support.
Dec 09, 2006 | Sony KDS-R50XBR1 50" HDTV
Panasonic PT-52LCX65 44" HDTV Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
