Question about Whirlpool Calypso GVW9959K Top Load Washer
My top load washer won't stop running water? - Whirlpool Calypso GVW9959K Top Load Washer
  • Whirlpool Master
  • 8,220 Answers
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't fill water runs out bottom
either you have a bad drain hose or the drain pump has a bad seal behind the outer case
May 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool GSQ963ILL0 top load washer. Stopped dead in middle of agitate cycle. I fear I overloaded it. Now just sitting, full of clothes and water, and won't do anything. Any advice?
Hi jim_zervas,
Firstly, unplug the machine. Then first thing to do is remove the clothing, and bucket the water out. Then run the machine again.
Let me know what happens?
Kind Regards
JEDEMEYER1
* Please accept my solution if it solved your problem
Sep 03, 2011 | Whirlpool GSQ9631L Top Load Washer
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | GE WDSR2080D Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Top load washing machine
Hi!!! looks like you have a bad timer..timers can be expensive..good luck
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
