Question about Dryers
How to replace heating element for frigidaire LEQ332DS0
  • Dryers Master
  • 8,220 Answers
Heating element on frigidaire dryer keep burning out
How many times???
Did you replace the Heating element with the housing or did you purchase the coil and ran through the old element housing. If you did the latter, make sure it will not touch the element housing and short out. This case you will see a black burn spark on the housing close to the element broken point. Did you lock in the heating element ends to the ceramic plate.
Aug 07, 2014 | Frigidaire Dryers
Why does my frigidaire leq332ds0 sound like it's overloaded when it's not?
Good Morning Nikki,
I understand your Frigidaire dryer, model# LEQ332DS0, is squealing like it's overloaded, even after replacing the belt. There could be a number of possibilities that could be causing your appliance to squeal. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine what is causing your appliance to squeal. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Dryers
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
http://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=5&ModelNum=fde336
Sep 10, 2011 | Frigidaire Dryers
Frigidaire dishwasher won't dry dishes. Less than two years old. Seldom used. FDB1100RHM. Could this be the heating element? Could this be something we could fix?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2011 | Frigidaire Dishwashers
My frigidaire dishwasher model # FDB4315LFCO, is ending the wash cycle with the dishes dripping wet, what might be the problem?
heatman101
Aug 14, 2011 | Frigidaire Dishwashers
WHERE IS THE HEATING ELEMENT FOR A FRIGIDAIRE FER341ACO
it is located on the back inside of the dryer, here is a step by step:
http://www.ehow.com/how_4866523_fix-frigidaire-dryer-heating-elements.html
I do not know why you want to replace the element but if the problem is no heat then here is another website that can help,Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 19, 2011 | Frigidaire Electric Dryer
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
Both heating elements in the oven not working. I did inspect the h. elements found no burn. thankyou help
Ok, you can confirm element failuer by testing for continuity with a Ohm meter. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Another reason, why the elements would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
If the elements show continuity, you will need to replace the entire control board(clock, EOC)..
Jun 01, 2009 | Frigidaire Kitchen Ranges
Frigidaire GLer642As3
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
May 12, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
268 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
