Wiring diagram for White Rodgers valve type 1311-102
Sebin
  • 712 Answers
SOURCE: how do I set up
Please refer the following link. It can be very helpful.
http://www.inspectapedia.com/heat/ZoneValves.htm
Thank You.
Posted on Oct 22, 2010
liteswink
  • 99 Answers
SOURCE: Lookin for wiring instruction in replacing old
The best thing to do here is to verify the function of each wire. You may need to call the manufacturer of the old thermostat to have that information. Then cross that with the WR stat. If have difficulty you may call hometechline 18002842925.
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: White Rodgers main gas valve operation.
pleas follow the troubleshooting page 9, 10 and 11
Posted on Jul 07, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: white rodgers zone valve will
Sorry to read about your problem, I hope this helps you out.
you will need to replace the zone valve, the spring that holds it shut is going bad. if you disconnected
the wire from the stat to the zone it will close
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 20, 2010
aquaman987
  • 927 Answers
SOURCE: installing a white rodgers thermostat. Need to
basic-thermostat-wiring-diagram.jpgGood luck, Gary
Posted on Sep 06, 2011
I have a White Rodgers 1F86-344 and I want to disable the wire for the Air Conditioner. I'm not sure which wire to disconnect for the ac unit only. Can someone assist me? I attached a diagram of the wiring
Without knowing how your controller is configured and what are the systems being controlled, it is a bit difficult to provide specific answers. In the appropriate configurations, the cooling system is controlled by the Y wire. I suggest you look at the wiring diagram for different configuration available at this site.
http://www.emersonclimate.com/Documents/White-Rodgers/Catalog_2010/2010_Cat_pg_157.pdf
A full instruction manual is available at this site and provides different operational modes which may not require that you take out wires but you can isolate the control using the selector switches inside.
http://www.emersonclimate.com/documents/white-rodgers/instruction_sheets/0037-6585.pdf
When working with the unit be mindful that full mains voltage is connected directly to it.
Sep 05, 2014 | Heating & Cooling
Wiring diagram white rodgers 1F82-51
Hi. This is Aaron Moratalla from White Rodgers. If you are looking for the wiring diagram of 1F82-51 see it in page 3 of the manual using link below:
http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-5650rev_A.pdf
If you need more help please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I need wiring diagram for thermostat white rodgers
Hi. This is Aaron Moratalla from White Rodgers. See this link for the copy of manual. http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6841.pdf
Wiring connections are on page 7. If you need more help don't hesitate to call Tech Support at 800-284-2925. Thank you for choosing White Rodgers.
Jan 17, 2013 | White Rodgers White-Rodgers 1F85RF-275...
Dec 10, 2009 | Heating & Cooling
Lookin for wiring instruction in replacing old buld typr Weathertron 3AAT86B!D1 with wiring as follow: Y-Yellow T-Brown B-Blue R-Pink W-White G-Green O-Orange X2-Black to be replace with White-Rodgers...
Nov 26, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Newly installed white-rodgers zone valve works for a while then eventually moves to manual (or open) on its own. Suggestions on how to keep valve in a closed position? Chris in Alaska
This problem has to be in the way the valve was wired. Wrong zone valve-Normally open instead of normally closed-power interuption causing valve to open. Faulty T-stat/ Most likely wired incorrectly.
Sep 13, 2009 | Plumbing
3 wire white rogers zone valve operated by 2 wire thermostat any one have a wiring diagram?
It is technically possible use a 2-wire thermostat with a 3-wire zone valve, but you need a single pole, double throw relay like a fan control relay with one normally open switch and one normally closed switch. 2-wire thermostats only have one switch that is normally open. 3-wire thermostats have two switches......one switch that is normally open, and one switch that is normally closed. The fan relay lets the 2-wire thermostat simulate a 3-wire thermostat. It's possible, but usually it's easier to just get a 3-wire thermosts.
Sep 06, 2009 | Heating & Cooling
Heating & Cooling Logo
748 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
