Question about Sony Ericsson K550i Cellular Phone
Unable to open cover of sony k550i
I m trying to open my sony k550i phone. i have unscrewed the two screws in the back but still the front not coming apart as it is stuck on the upper part. is there another screw on the upeer pannel also ?why it is not fully coming apart????
  • 2 more comments
  • vikram123456 May 30, 2008
    it doesn't have sony k550i
  • vikram123456 Jun 03, 2008
    i hv already removed two flower shaped screws under the battery cover. Now the front cover is coming apart but it is not coming fully apart...it seems glued on the upper side(where the power button is)....i wanted to know, r there more screws on that side?
    thnx
    thnx
  • Anonymous Aug 25, 2008
    i want to use my sony ericcsion k550i phone as web cam is it possible?
Hi i just had the same problem but now i found out it does have two small screws at the top under the back cover.
step one: take off the battery panel
step two:un screw the two flower shaped screws under the battery cover
step three:push the top back cover up and it will just pop off you may need to give it a bit of force but be carefull as not to break it
step four: the front should now just pull off (if it doesn't use a old bank card or something to go around the edge to undew the clips.
ALL THIS ONLY WORKS ON THE SONY ERICSSON K550I/M
I HAD TO DO THIS AS IT GOT WATER DAMAGED IN THE WASHING MACHINE FOR AN HOUR AND A HALF
BE WARNED NOT TO GIVE IT TWO MUCH FORCE.
Posted on Jun 02, 2008
    Guru:
  • 1,463 Answers
Thanks for the tips now i can replace my lcd screen
Posted on Oct 19, 2008
@ guest Solution #3:
You need a torx screwdriver.
Posted on Sep 25, 2008
How did you unscrew the two flower shaped screws no screw drivers work
Posted on Aug 29, 2008
MAN THANKS...I SWITCHED TO A WHITE CASE.LOOKS AWESOME!
Posted on Aug 24, 2008
Cannot open games and application in sony ericsson k550i...
i think you have downloaded the games of unsupported format.try to download games at your phones specification
Sep 13, 2009 | Sony Ericsson K550i Cellular Phone
Received replacement lamp, opened back panel and can't the old 1
There is a small door on the lower side of the TV with a couple of screws that keep it shut.Take the door off and the Lamp assembly is in there held by a screw. Take that screw out and pull the metal handle and the lamp slides out. Reverse instructions to install. Make sure the compartment door is secure because it has a safety switch that keeps the TV from operating if it is not fully closed.
Aug 06, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Phone lock code of k550i
my k550i is locked.i have forgotten the code.how to open the lock?
Feb 24, 2009 | Sony Ericsson K550i Cellular Phone
A screw has come loose behind the slide bit of my phone
REMOVE THE BACK PANEL AND ALSO THE BATTERY AND THE SIM U WIL SEE FEW SCREWS UNSCREW THOSE AND NOW THE FRONT PANEL WIL BE LOOSED SO THAT U CAN NOW REMOVE THE SLIDE BUT TO DO SO U MUST BE VERY CAREFUL THERE WILL BE MANY LOCKS SO WATCH THOSE AND REMOVE CAREFULLY TO TIGTHEN THAT SINGLE SCREW U MUST UNSCREW THE WHOLE MOBILE THANK U
Feb 23, 2009 | Sony Ericsson W910i Cellular Phone
Sony bravia 50 in lcd rear projection tv picture dark most of the time
take out screws ob back side around the edges not bottom. the grill that covers the speakers comes off by taking out screws on back in the middle of round knobs after screw is removed unscrew knob. then remove screws next to speakers then remove front of tv clean mirror in back. if that dosent work replace bulb.
Nov 20, 2008 | Televison & Video
Sony Ericsson K550
How do i remove the front cover, there is dust behind the screen
Aug 17, 2008 | Sony Ericsson K550i Cellular Phone
Problem in games & applications
unable to open games and applications folder.- error is showing = "operation failed " kindly help
May 07, 2008 | Sony Ericsson K550i Cellular Phone
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Ericsson K550i Cellular Phone Logo
2,923 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
