Question about GE PSW26MSR Stainless Steel Side by Side Refrigerator
My GE side by side refer will not supply cube ice, but only crushed no matter which button is pressed. How can I get inside the dispenser unit to fix it?
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
larryyb
  • 291 Answers
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
Posted on Dec 04, 2008
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
aasc
  • 1606 Answers
SOURCE: GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
http://www.apdepot.com/Buy/IPLFrame.asp?Brand=GE&ModelNo=GSH25KGMDWW&IMGFile=LD1IEWSN&IMGID=uZmA
Posted on Aug 15, 2009
My GSH22k gre makes only dispenses crushed ice
You've got a bad solenoid. The "trick" only works sometimes.
Jan 16, 2010 | GE GSS25LGM Side by Side Refrigerator
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Frig 2 years old It make crushed ice when you press the cubed button. It's making cubed ice fine just not dispencing everything else works fine. It is model No. GSH25JSTASS and Serial NO....
could be a problem with micro switches inside the dispenser. it has small switches that when you press the button outside, you are pressing a switch inside and if they are cross wired or what ever, these things happens. if you are familiar with electrical wiring trouble shooting, then i could guide you but if not, then i suggest you call a qualified tech to help you with this kind of problem.
it is as if the wires were interchange. cube button would dispense crushed ice then the crushed ice button is not working.
tnx 4 using fixya,
drcool
Oct 07, 2008 | GE Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
GE PSW26MSR Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
