Question about Sony Audio Players & Recorders
I bought a Sony PS-LX2 turntable online. When I received it and plugged it up the turntable is running at a high speed and won't slow down. The servo lock light won't come on. Any suggestions?
4 Suggested Answers
  • 42 Answers
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
djproaudio
  • 515 Answers
SOURCE: Cannot adjust speed on a vintage Technics SL-B30 Turntable
More than likely it is a faulty drive IC (Integrated Circuit). If so, your out of luck, because most parts for this unit are discontinued, with the exception of the belt.
There really isn't much else you can do. Will probably cost too much to repair, if you can find someone who can repair it.
Sorry couldn't be of much more help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Parts : Turntable Repairs
Posted on Aug 30, 2009
Grubhead
  • 5126 Answers
SOURCE: Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Posted on Jan 26, 2010
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
Fix speed and pitch problem sony ps-t15 turntable
The pitch control need to be cleaned. You will have the remove the bottom to do this. It will require servicing. It could also be PCB board that that controls the pitch or a bad motor.
Jan 02, 2014 | Sony Audio Players & Recorders
I have a sony ps-lx10 turntable, and want to connect it to a non-Sony system. The power ribbon needs to be modified. How do I do that?
First of all you would need to know 2 things. One the voltage supply needed to run the turntable. Two the voltage outputed by the non Sony system. If these don't match you could have a problem. For example if the Sony Turntable runs of say a 6 volt supply and the system puts out say 12 volts. You will damage the turntable. Chances are unless the non Sony system was actual made by Sony under a different name then the two supplys will not match. If you can connect up the two the Turntable will either run slow or fast. If the output supply is only 6 volts and the turntable motor works on 9 volts or higher you will never get it to run at the correct speed.
If you work out the two work off a similar voltage, you need only connect the plus wires together and the negative wires together and the motor should turn. Most turntables have speed presets, for each speed. You will need to find them and adjust them to get the speed right on each speed.
Dec 30, 2012 | Audio Players & Recorders
I have a Sony PS-LX210, and need to adjust the speed. Going by the music it's played, it's just a bit slow on 33 RPM (I don't know about 45). I find no external adjustments, but there are some trim pots...
According to anything I can find online, like any decent turntable it has a manual pitch control. Unfortunately, I can't find a manual or even a good close-up picture.
This is the best one I've found.
http://www.neowin.net/forum/topic/652451-post-your-vintage-tech/
What's that rectangular slider-looking thing at the front right edge?
Feb 10, 2011 | Sony PS-LX250H Turntable
Sony PS-LX250H is running slow from time to time notibly when playing slower songs like John Denver 33 albums.
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
May 17, 2010 | Sony PS-LX250 Turntable
Jan 08, 2010 | Sony PS-LX250H Turntable
Sony ps-lx2 turntable clicks when spinning
Jan 01, 2009 | Audio Players & Recorders
Uneven speeds
belt came loose please help[
Jun 24, 2008 | Sony PS-LX250H Turntable
349 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
