Question about Samsung SF-340 Plain Paper Inkjet Fax
How is Result OK deinfed for a transmission - Samsung SF-340 Plain Paper Inkjet Fax
My car will not go in gear at all
year make model auto or manual
Mar 22, 2015 | Cars & Trucks
My oldsmobile silhouette2000 does not shift gear when in drive
Hi.
Check the TPS (throttle position sensor). The TPS is located on the throttle body. Its signal is used by the transmission control module to decide when to activate the solenoids and switch gears.
The TPS can be tested by reading volts at its terminals while someone else is pushing down the accelerator pedal. If voltage has gaps (in your case this is likely the result), or if voltage does not change smoothly, then the TPS must be replaced.
Other part that can be responsible is the speed sensor, mounted on the transmission. This part is more difficult to test, and gets usually replaced if TPS and solenoids are OK.
The transmission gears are operated using an array of solenoids called solenoid pack. The solenoids are located inside transmission, in the valve body. A shorted solenoid can cause the transmission getting stuck in gear. An open solenoid will result in one gear not working. The solenoids are tested using an Ohm meter. If a solenoid is open then it must be replaced.
Wiring to solenoid pack must also be checked to be sure that the problem is not the wiring harness.
If all the rest is OK, then the TCM (transmission control module) or a defective transmission box can be responsible for the problem.
Transmission problems may store DTC (fault codes) in the ECU (Car main computer). If an obdII reading done on the ECU returns DTC P0700, that means that there are more codes addressing specific transmission codes stored in the TCM. A scan to retrieve TCM codes can be done at the dealer.
If first gear does never kick in, then I think the problem is likely a blown solenoid. The TPS can be tested first as it is an easy job.
Regards.
Ginko
Jun 13, 2011 | 2000 Oldsmobile Silhouette
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
report lists the time and date of transmission and whether the transmission was successful
(OK). If you choose On or On+Image, the report will print for every fax you send.
If you send a lot of faxes to the same place, you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is turned Off or Off+Image, the Report will
only print if there is a transmission error, with NG in the RESULT column.
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
I tried to send a fax & its says "memory full" . How can i get it to clear the memory?
If memory is full (0% appears on the display), Memory Transmission is disabled.
After you press the {OK} key, you can select whether to transmit pages which have been stored in memory or to delete those pages. Check the number of transmitted pages on the Communication Result Report when you select to transmit those pages.
If you can not find how to erase the faxes in memory you can Use Immediate Transmission instead
Feb 10, 2011 | Ricoh Aficio 1013F Copier
I would like to print a transmission report for a document that I just sent.
Hi
You can print a log of faxes that have been received and sent by the device. Each
entry in the log contains the following information:
• Transmission date and time
• Type (whether received or sent)
• Fax number
• Duration
• Number of pages
• Result (status) of transmission
To print the fax log from the device control panel please follow the directions below
1. Press Setup.
2. Press right arrow to select Print Report, and then press OK.
3. Press right arrow to select Fax Log, and then press OK.
4. Press OK again to print the log
All the best!!
Regards
Nov 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
2003 Sierra 2500hd transmission or transfer case making grinding noise (sounds like a bearing going bad) it becomes louder when i give it gas. i checked the fluid in the transfer case which looked ok, i...
Sudden grinding noise with no prior warning * Primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
* Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
* Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
Good luck and thank you for using fixya.
Mar 17, 2010 | 2003 GMC Sierra 2500HD
Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Discontinue fax transmission report
Press;
  • User Tools/Counter button
  • Facsimile Features
  • Key Operator Tools
  • Parameter setting
  • Select Switch No. 03
  • Select Bit No. 5 for Immediate Transmission and
  • Select Bit No. 0 for Memory Transmission
When the Bit number is pressed, the current value switches between 1 and 0.
Please set these two Bits to 0 to disable printing of transmission result report.
Then press;
  • OK
  • Exit
  • User Tools/counter button
Good luck and please rate me, thanks.
Jan 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Samsung SF-340 Plain Paper Inkjet Fax Logo
138 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
