Question about Miller Hobart AirForce 250A Plasma Cutter w/Builtin Air Compressor
I have the Hobart 250 model. I have gotten much use from it. Recently I was using it, I wouldnt say over using or abusing either. I put it up for the day, and when I went to use it the next, it simply just wont come on. No power light, no fan nothing. I checked power to the switch, good, from the switch out, good, and going to the board, good. I read about thermal fuses, although cant seem to find one as is described on other posts. Any help to the problem is great, thanks.
Same problem here did you fix it?
Posted on Feb 12, 2011
Can i power this unit with my old Miller Bobcat 225. Also what gun do you recommend?
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
Dec 21, 2010 | Hobart Welding Tools
1992 dodge w-250, took her in for a service...bleed fuel lines...
It sounds like you are talking about a diesel engine as gas engines are self priming. Lift pump or primer pump may be defective. Check for loose fittings or lines and damaged o-rings at filter housing. Sounds like you are sucking air somewhere.
Jan 30, 2010 | 1992 Dodge Ram 250
2006 ford f150 4wd drive will not disengage
Transfer case and shift linkage need servicing. Sometimes customers have gotten away with just a simple lubrication.... others a rebuild.
Jan 11, 2010 | 1996 Chevrolet Tahoe
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Need manual for hobart g-250 welder
Go to this page on the Hobart website....you can enter your model and the serial and it will allow you to download the manual...
Click here
May 25, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
Excessive wire speed on hobart ironman 250
to find out if you need a new reostat disconnect the wires from it and put an ohm meter on it and check the ohms resistance it should read up and down ohms as you turn the dial.
Mar 02, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Hobart engine drive welder has no power out put
i took an old trickle battery charger,6 volts and energize the armmiture,all so called polarizing,google it ,shows how also
Jan 26, 2009 | Hobart Welding Tools
MIG 250 welder torch tip
its a Hobart copy. Use tips intended for a Hobart, and always be sure to use tips that are for the same gauge of wiring you'll be using.
Oct 21, 2008 | Astro Pneumatic 3 Pk. MIG Welder Torch Tip...
Horbart dishwaser wont dran
Its a hobart correct?The data plate is on the bottom right front or on the door when opened on the left.If you dont see it then its been removed.Regardless does the display show a wash then rinse cycle?If so and it doesnt drain you either have a clogged drain hose or the drain valve is bad or stuck.If you use this just to wash glasses your model is probably a lxigc.If glasses are broken in the dishwasher which they probably are the glass has gotten into the drain body and is obstructing the valve from opening and closing.I work for hobart and services dishwashers alot.let me know.
Feb 21, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Miller Hobart AirForce 250A Plasma Cutter  w/Builtin Air Compressor Logo
306 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
