Question about General Electric Dryers
Our GE clothes dryer stopped running during the drying process and had to be restarted several times. Now it has stopped and it won't restart. Any suggestions?
  • General Elec... Master
  • 8,220 Answers
First look for lint build up that could cause limits to kill power to the motor Clean the dryer and vent up. Check the element. It might be shorted to the pan. How to get into the dryer and repair photos HERE
Posted on Oct 07, 2010
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer starts fine after a couple of minutes shutts of, I have to restart it several times untill clothes are dry.
most dryers have a sensor that is supposed to shut off auto matic when clothes are dry look at your choises on the dry temperture. one of them usually have automatic whites auto colors etc. the sensor sounds like it went bad. most of them are near the exhaust pipe.it measures the moisture level to test it remove the wire or wires. then try running the dryer for a little while.
Dec 29, 2011 | Roper Dryers
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
Dryer stopped, will not restart. Overheated.
you need chek :
1-bushin motor
2-bushin drum.
Oct 06, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes...
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Apr 13, 2009 | Dryers
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Electric kenmore he 3 dryer what is code E-1 mean
This code is for a part called a "Thermistor". Its like a thermostat for an electronic machine.
Sep 06, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
114 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
