Question about Parmak Solar Fence Charger
Installed the new solar charger in July. ZThe hot wires and ground wires are properly connected, snd the fence is properly grounded. It worked great until approximately two week s ago (end of Sept). The battery slowly lost charge, and would not recharge. It is completely dead now. I have checked and re-checked all connections and the fencing to be doubly sure that there wasn't something that had damaged the battery; however, everything is in order. Please help!
    Sergeant:
  • 268 Answers
I have see this happen before and its usually do to most moisture/rain getting in. ie use multi meter to varify solar charger putting out current/voltage. Odds are its not anymore. Rechargable batteries are notorius for not lasting but not in 2 months.
Posted on Oct 07, 2010
Hi, I have a 25 mile range Parmak solar pak 6 fence charger. When I test the lines it reads .02 and I noticed that the energizer unit itself is energized. I tested the unit and it reads between 3.8 to 4.6....
Any point you measure has to be compared to a reference. This can not be accomplished by just touching one spot....it must be compared to something. Do I make sense the way I explain this?
Hope this helps! Good luck
Dec 30, 2013 | Electrical Supplies
How do i hook up gallagher s20 solor fence
Jill, If there are only two wires, and the battery is already connected to the solar panel, and the solar unit or the fence is not connected to anything else, then it doesn't matter which is which. However, if you are hooking to the battery or to something else, then it DOES matter. That said, the universal color code is green for ground and red for hot.
Good luck.
Jun 21, 2012 | Saws
I have a Parmak Model DF-SP-LI. With a volt meter it reads 2.3 on the fence, but the performance meter is always reading beyond the green.
It depends on the type of fence tester. the common light-o-meters are a resistor ladder, calculated not only for voltage but current. the DF-SP-LI uses half the lowest current most are designed for. no if that is a digital or analog meter, then it would be time to check the out put from the charger with out the fencer connected. if you get the same reading it maybe defective unit. if you get a better reading then you will probable need to upgrade your ground system. insuffencient ground will show its self as a low out put on the fence but not on the charger.
May 20, 2012 | Parmak Solar Fence Charger
When I hook up the ground wire the meter shows not working but when I unhook it, it shows full power.
It sounds like to me that you have something shorting the "shock" output to ground. Check your fence to see if there are any plants, or other objects touching the "Hot" wire to the ground. You could also have a broken or cracked insulator that is causing the short circuit on the output.
joe
Jan 05, 2011 | Parmak Solar Fence Charger
Need battery
We have one of these, it's great.
See these links:
http://www.parmakusa.com/Battery_Maint.htm
http://www.parmakusa.com/service.htm
I would try removing the battery and charging it with a proper low-amperage charger (1 amp). Your battery will either be 6 volt or 12 volt, just be sure the charger matches.
Also check the ground rod and all wiring connections.
May 13, 2010 | Parmak Solar Fence Charger
I bought a Parmak Solar Pak 6. I wanted to use it
when you touch the wire, you are probably wearing shoes, which ground you,
touching it barefoot or kneeling on bare knees should provide a bit more jolt.
take your multi-meter, shove one probe in the ground and touch the wire with the other and you should get a nice reading
May 08, 2010 | Parmak Solar Fence Charger
We have 2.2 miles of fence,the charger is good for 30 miles.We have a 8 ft ground rod by the charger. the fence is a continues loop. positive wire to fence, negative to ground. meter on the charger says it...
You have got to make sure there are no weeds or brush at all touching the hot wire. Nothing can touch it or it pulls the voltage level way down. Do a full inspection of line.
Oct 02, 2009 | Parmak Solar Fence Charger
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Parmak Solar Fence Charger  Logo
417 people viewed this question
Top Parmak Electrical Supplies Experts
Craig Butler
Craig Butler
Steve Pack
Steve Pack
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
