Question about Philips Magnavox MS3252S 32" TV
What is the Chassis # for this model?
We need to have this TV repaired and the Chassis # is disintegrated from the back of this 4 yr old TV
  • Janie1956 May 29, 2008
    The label on the back is disintegrated, so we cannot read it. Any other ideas?
  • 790 Answers
Hi
the chassis number is located at the back cover of Tv, and to PCB.
Thanks!
Posted on May 29, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Jun 02, 2008
    yes! open the Tv cover then you can see the chassis number at the main PCB Circuit!
My bush tv is 2 years old and has 2,sometimes 3 vertical lines running down middle of screen.what could be the problem please.x
Hi Roberta.
its the horizontal circuit fault in the Tv. Look back from the Yoke socket and from the two red and blue terminals and you you will get into the horizontal circuit
uusually its components starts with the number 4 at the Tv chassis
resold the components there good and this problem will be fixed
as its a solding loss or track cut at the tv chassis
you need to be familiar with tv repair to do this or get technician to fo thid for you
May 06, 2015 | Bush Televison & Video
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have a 10 yr old Sony FD Trinitron WEGA 32" Flat
Hello jorge and welcome to FixYa. With your particular model of television six blinks mean a Horizontal Drive Failure has occurred. If you have any television repair experience you could try checking the jungle for loose or possibly bad soldering. In some case the jungle IC was found to be defective on this model as well. You should also inspect the horizontal drive transformer windings if at all possible. If you are unable to repair this yourself I would personally say to you no it is not worth the cost to repair it as purchasing a new television would probaly be a more prudent decision. I hope you found this helpful and thank you for visiting FixYa.
Apr 23, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture yube for 20 yr old quasar tv everything else works great!!! need new one
Sorry you won's be able to find one but you can have an alternative picture tube model for your TV ! just go to your lock TV repair Shop they will suggest you!
Mar 03, 2011 | RCA Televison & Video
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
No Picture on a 4 yr old TV
I would take it to a repair shop, but it sounds like somewhere in the power board.
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a 52 inch RCA projection TV about 15 yr old today the colours are not lining up causing a shadow of red behind white lettering and looking like a 3 D show withought wearing the proper glasses?
you need to replace the convergence supply board, if it's one of the earlier models, you change the chip stk730-130 that will fix it. the board is small and up off the chassis to the right slightle, 4, 1/4'' screws holds it in place.
you might be able to get a whole new board, which would require no soldering to fix.
Sep 15, 2009 | RCA P52926 52" Rear Projection Television
Galaxy Saturn turbo does not come on.
check CBtricks.com and see what they have
Jan 12, 2009 | Galaxy Radios DX-2517 CB Radio
No sound or picture
jerel,
Please provide accurate info for best solution = on back of set =
Model # , service # , chassis # , Mo / Yr built............
Stopped playing = Dead ? ....no sound , no picture, no green
power led on front??...........................Help ! Let me know..T.
Nov 25, 2007 | RCA P52926 52" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Philips Magnavox MS3252S 32" TV Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
