Question about Dishwashers
Ge profile dishwasher, What does "1h" mean on the display????
5 Suggested Answers
SOURCE: I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Posted on Jan 10, 2009
ginko
  • 19396 Answers
SOURCE: GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Posted on Mar 13, 2009
SOURCE: purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Posted on Aug 06, 2009
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
A GE dishwasher GDT580 that's displaying code 1H or IH and will not start
that's not an error code. it's a 1H, as in one hour, the delayed start function. hold the delay start button down to override, then reset it back to where you want it.
Aug 27, 2015 | GE GDT580SSFSS 24" Stainless Steel...
What does IH MEAN ON MY DISHWASHER G.E.
Instead of IH, could it be 1H (as in "one hour")? Sounds like you activated the 1 hour delay function. If so, press the "Delay" button a few more times to turn off the delay feature.
Oct 05, 2014 | GE Dishwashers
My ge dishwasher won't run. it displays an error code 1h
hi heres what i found The 1 H is not a fault code it is the delay time of one hour.
Jul 12, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
What does display code 1H on GE Profile dryer mean?
It means you have it set for a 1 (one) hour delay start
Nov 23, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Error code
you have set it to start after a one hour delay- just press the start delay button until it cycles through past 24h and you will get back to the immediate start mode...
Oct 12, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
382 people viewed this question
Top Dishwashers Experts
