Question about Electronics - Others
Transcend pen drive replacement
I rakesh singh pawar purchase a 2gb transcend pen drive through sifymall (online) .After one month it is not working .Where we claim for warranty.
  • bhavnababby Sep 02, 2008
    I too have the same problem.Whenever i insert my pen drive the removable disk (E:) appears,but when i try to open,it says "Please insert a disk in the removable disk (E:)".Suggest me a solution to make it work.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Transcend pen drive problem
Since you are using Vista, you may want to check for an update/patch from the laptop manufacturer. This is a common issue with Vista's USB ports. Microsoft has acknowledge the issues and has posted a fix here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 25, 2008
SOURCE: Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Posted on Oct 31, 2008
bob_computer
  • 3153 Answers
SOURCE: Transcend 2GB jf v30 pen drive not getting detected in vista OS
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 10, 2009
laikexpert
  • 281 Answers
SOURCE: i cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
My 2GB transcend pen drive is not detect in my computer
My 2GB transcend pen drive is corrupted how to restore
Mar 07, 2010 | Transcend T.sonic 612 MP3 Player
My 2GB transcend pen drive is not detected by any computer.this is the first time. pen drive JF V30/ 2GB , Mic-D33193 and SrN. 510747 1741 Please Reply me.
My 4GB transcend pen drive is not detected by my computer.I have use it before 2 times. pen drive JF V30, S/N. 302925-0046 Please Reply me.
Dec 30, 2009 | Transcend T.sonic 612 MP3 Player
update your computer's USB driver with version 2.0. Make sure you installed your motherboard's USB support drive dont just rely on the USB driver provided by microsoft.
Jul 29, 2009 | Transcend (589307) Media
I Have 8 GB Pen Drive. my Pen Drive Not Detected on any Computer. I Try My Computer Manage Path But Till Same Problem i facing is that any software or any repairer in mumbai. please help me. Vikas
Dear,
If you want to repair your pen drive, then just visit your nearest transcend service centre. It is the best solution dear,
Regards,
Rakesh Kumar
Apr 24, 2009 | Transcend (589307) Media
Transcend pen drive 16gb+write protected
Dear,
No, problem
Just copy the whole data of pen drive to PC. Now format the pen drive
and paste the data from PC to pen drive again. It will work fine then
Thanks,
Regards,
Rakesh Kumar
Apr 01, 2009 | Electronics - Others
Transcend 2GB pendrive is not working .
You can format the pendrive and see if it works or else get a replacement as transcends have a 2 years warranty.
Jan 27, 2009 | Transcend (589307) Media
Pen drive not working
my 2gb transcend pen drive is not detecting or hidden
Jan 03, 2009 | Transcend (589307) Media
Transcend JF V30/2gb not working in VISTA. the messege is Application not found,
hello
i have transcend JFV30/2GB pen drive , but its not open in any comuter ,
Aug 11, 2008 | Electronics - Others
Feb 27, 2008 | Transcend (589307) Media
Electronics - Others Logo
82 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
