Question about Dishwashers
Kenmore model 665.17033403, stock 17033, when wash starts it reads sensing, makes some noise, reads washing but nothing happens
  • 2 more comments
  • cthom57 Oct 08, 2010
    hey..I had to try the button sequence 4 or 5 times before it finally did the lights
    no..the problem is not fixed...did you get my comments sent earlier today...took 4or 5 tries of the button sequence before the diagnostic cycle worked...then still no wash...let run for 10 min it appears the element came on as it was hot inside...but no washing happened..
    ..tried unplug (breaker) and first sequence..no luck..tried 2nd sequence, when press normal the heated dry comes on at same time, when press heated dry it just goes off, leaving normal light on, note the lock light is set to off. So I tried sequence, heated dry-normal-heated dry-normal and all the lights came on but still no luck for washing...I can hear water filling then silence then after few minutes some water drains and silence..it is warm inside, but through all the resets no water has sprayed inside, also tried running hot water to make sure hot as possible before start...anything else to try
    ok thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
  • 1 more comment
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    Great! Please accept the solution if the issue is resolved or post a comment for further assistance.
    Rylee
  • Rylee Smith
    OK, unplug it for 10 minutes and then try this again you can also try NORMAL WASH-Heated Dry-Normal Wash-Heated Dry in sequence.
  • Rylee Smith
    Check the door switch before replacing the control.
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Squeaking noise while washing is going on. No noise at any other time. Repair man checked brake and said it was good. Any help would be wonderful as the noise is driving me crazy. Kenmore model...
Have you or did the repair man check the belt to make sure it was still good and nothing was stretched? Also the motor to make sure that it was not causing this problem? And everything is oiled properly?
Feb 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Dishwashers Logo
170 people viewed this question
Top Dishwashers Experts
Owen Barnes
