Question about Kitchen Ranges
Service manual for kitchenaid oven model KEBC208KSS0. Need to replace control thermal fuse
2 Suggested Answers
Cyril J
  • 45 Answers
SOURCE: Kitchenaid Selectra Range Fuse location?
unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
Posted on May 16, 2008
Kitchenaid Superbra double wall oven still not heating. Replaced thermal fuse of top oven; lower is OK. Also replaced the 2nd thermal fuse near the control panel on the top of the unit. Any ideas?
Get me a complete model # number for this oven We then can give you step by step what to check .Knowing how to use a meter Is a big help with any electrical issues . Getting Us the model will tell us what is used to control your appliance, The big and first thing to check is the power do you have it all were it needs to be most ovens run on two legs of 110/120 volt. in combo Make 220 volt It all needs to be there or you will not get proper heat
.https://www.youtube.com/watch?v=NOdYp8CFjdU&feature=share
Feb 02, 2017 | KitchenAid Ovens
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
Dec 06, 2014 | KitchenAid KEBC208 Electric Double Oven
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Kitchenade
Kitchenaid is made by Whirlpool. They have had a problem with the self clean getting too hot and shutting down the control board thermal fuse. If you can access the control board. (power off) there should be a small inline thermal fuse attached to a connector usually on the far right of the control board. It is encased in a clear plastic tube. Test this for continuity. If it is bad replace this fuse and the display should come back on. They also have a thermal fuse on the back of the oven that usually goes out at the same time. If the oven and broil don't work after fixing the control board thermal fuse. then you will have to pull the oven out enough to take the back panel off and check this fuse.
Feb 09, 2014 | Ovens
I have a Kitchenaid oven model KEBC107KSSO. After using the auto clean, broiler and oven does not heat. Control panel works fine.
The thermal fuse on the back of the oven is out. Usually happens if the oven is installed incorrectly or the blower is too small to cool the back of the oven down while in self-clean mode.
I'd call KitchenAid (whirlpool) and ask if it needs the blower kit to fix it. Have your model&serial numbers handy.
In case it does not need the blower kit, the thermal fuse part number is 9759242, and it can be purchased here (use coupon "New10" for 10% off). Read my other post for the instruction how to get to the thermostat.
Oct 14, 2009 | Ovens
I have a Kichenaid microwave Model # KCMS145JSS-1 No lights, no readout, completly dead. Power source checked and o.k. Any thoughts?
I would suspect the fuse, the magnetron's thermal cutout / thermostat, or the oven cavity thermal cutout / thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | KitchenAid Microwave Ovens
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
I have the same problem as djeff757 post on Kitchenaid KDRP467
I don't recall a control panel fuse for this model, there is, however, a thermal cut-off on the rear of the unit. The part number is 8300802 and you simply have to remove the rear panel to access it.
Dec 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Mar 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchen Ranges Logo
152 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
