Question about Maytag Appliances Over-the-Range Microwave Oven
I WAS JUST INFORMED THAT I HAVE TO REPLACE THE ENTIRE DOOR FOR MODEL MMV5165BAS AT A COST OF $285 FOR THE DOOR AND $125 TO INSTALL. I LOOKED FOR THE PARTS FOR THIS MODEL AND ALL IT SHOW IS THE DOOR ASSEMBLY.
    Champion:
  • 248 Answers
Web search-AppliancePartsPros.com-,should solve your problem
Posted on Oct 08, 2010
MMV5165BAS door won't latch
The latch may be broken or defective and will have to be replaced.
Jul 08, 2014 | Maytag MMV4205 Microwave Oven
Broken handle on maytag stainless steel microwave. Do not wish to purchase complete door assy. Could possibly substitute a black handle. Model MMV5165BAS. Kindly advise
around the inner side of the door between the window and outer frame is a plastic shroud,by gentle prying it out using a flatblade screwdriver starting at the handle side working toward the hinge side it will pop off and the screws that hold the handle can be accessed and remove and replace the handle. to reinstall that shroud gentle push it in with your fingers
you can go to searspartsdirect and enter in your model number exactly as found in the mw cavity and order the part or perhaps look in your phone and find a appliance parts dist. in your area
Jul 19, 2011 | Microwave Ovens
Door handle broken. I want to find a replacement handle without replacing entire door.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
Model mmv5165bas Door handle is broken - how do I replace the handle? Thanks JEFF
If your full model number (from the tag in or on the unit) is MMV5165BAs, then you'll have to replace the entire door.
If your model is one of these, the handle is available separately, with part numbers below:
MMV5165BAB14 or MMV5165BAB15 black part number W10189508
MMV5165BAS14 or MMV5165BAS15 stainless part number W10187840
MMV5165BAW15 or MMV5165BAW16 white part number W10189509
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 06, 2010 | Maytag Appliances Over-the-Range Microwave...
I need a new door for this microwave. I have been looking online for hours and can't find just the door. Can anybody give me a website that sells just the door for this micro? Thanks....
The door is available at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for the ENTIRE door is WB56X10585.
Is there a reason for replacing the entire door? You can purchase individual replacement parts if only a single part on the door is broken. The first three sites on the list have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
The most common thing that fails on these doors is the door handle. If only the handle is broken, the door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part numbers for the handle on this model are (2 pieces):
WB15X10119
WB15X10120
If you have any questions, please post back with your and let me know. I hope this helps you
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace door?
If the model number is correct, the door on the microwave comes off by opening it all the way and lifting straight up at the hinges. The entire door will lift off the hinge pins and come off. You may have to remove the upper grill cover above the door to accommodate removing.
If this is a simple matter of just needing to replace the door handle, or broken panels, you can save money by replacing only the parts you need. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually runs about $20 - $40. Replacements (if required) may be purchased at the websites listed in the link I provided.
The door handle, or other miscellaneous parts are usually simple repairs that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
What I have provided you with is the basic information that applies to most ovens. If you have any questions, please post back and let me know. I hope this helps you.
Apr 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
Feb 13, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 10, 2009 | Microwave Ovens
The door handle broke off of my built in microwave MMV5165BAS
To replace the handle, normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 10, 2008 | Microwave Ovens
Maytag Appliances Over-the-Range Microwave Oven Logo
212 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
