Question about Health & Beauty
How to remove rubber smell from rubber boots - Health & Beauty
  • 490 Answers
Only time will do that. Rubber smells. Leaving them outside on the porch helps a little, but the smell will gradually fade over time. You can mask the smell briefly with fabreze, but this is not very effective. farmerbear at FixYa
Posted on Oct 08, 2010
Cabin exhaust smell
Since you do have exhaust smell in your cabin,I suggest to check the rubber sealer at the rear boot door. As the exhaust end is at the rear boot door side, it is the only place which allow the smell to get in the cabin,since the rubber sealer is either broken,cracked or softened and do not seal well the boot.
Jan 02, 2013 | Toyota Highlander Cars & Trucks
SMELL OF DIESEL IN SIDE CAR
Smelling gases from outside usually means one of your rubbers have failed. Inspect all the rubbers on the firewall and the boot rubbers. May also be coming up from around the gear stick.
Mar 05, 2012 | Mazda 2 Cars & Trucks
Cleaning rubber door boot
I am not sure how the Whirlpool rubber boot is constructed but the Maytag's can be pulled back enough to get a sponge, washcloth, etc. around it to clean it. If you can get to it try a product like odorban which will clear up any mold, mildew & icky smells without harming the rubber itself.
Mar 03, 2010 | Whirlpool Washing Machines
I have always had a smell coming from my duet washer. I put bleach in and run it through a rinse cycle, but it always comes back
there may be some dirt or other things collecting in the drain boot attatch to the drain pump there is usually a plastic coin trap located inside the rubber boot his will cause a musty smell in the washer.as well as a moldy door boot seal.if the door boot is moldy it needs to be replaced.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I get rid of the stinky smell of my front loader?
The smell comes from your front rubber boot you must replace it toget rid of the smell.The water collects in the inner part of the boot and and sits there till it smells hope i helped
Sep 20, 2009 | Kenmore Elite 45986 Front Load Washer
A smell of burning rubber is coming from my engine. What is it? Could it be the timing belt? Is it safe to drive any distance? Thanks I have a burning rubber smell in my Subaru 2003 Outback, - any...
Check serpentine belt, the radidator hose , the air conditioner compressor and also the differential seal they common cause for rubber smell.
Check for any rubber part that can be in contact with exhaust system and inspect wirings looking for shorts.
Also ensure that the smell is not coming from a bad tyre, and check for oil leaks in your engine, burnt oil can be confused with rubbere smell.
Mar 05, 2009 | 2003 Subaru Outback
Foul odor
Run the washer on the hottest setting you have with nothing but a cup of bleach in the tub. Pour the bleach through the dispenser so it cleans the dispenser as well. Run the washer like this and let it complete the cycle. If the smell persists, remove the lower kick panel under the door and check the drain trap on the drain pump for anything that could be caught in the pump and making it smell. This odor can travel back into the the wash tub. If you decide to open the drain pump, however, here\'s a bit of advice. There is some residual water that stays in the drain lines and pump (this is normal). If you remove the drain trap cover, all this water will come gushing out. To avoid this, take the drain hose out of the standpipe and use a wet/dry shop vac to pull this remaining water from the tub and lines. This will save you from a big clean up later. Lastly, you mentioned you\'ve been cleaning the rubber door boot. Are you using 50/50 mix of bleach water in a spray bottle? Are you cleaning the area behind the door boot where it meets the wash tub? I ask this because once mildew sets into the rubber it\'s hard to get rid of it unless you use something with chlorine in it to kill it. Also, articles of clothing get caught in this area and can begin to smell. Not to mention, all the nasty residue left by soap and detergent. If all else fails, and you have tried all the advice, the last thing I have found that works, is to simply replace the entire door boot. Try the cleaning options first, and if you still have problems let me know. I can give you step-by-step advice on how to change the door boot if you wish to pursue it. The cost, by the way, is about $80. I hope this helps you.
Sep 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Smells of mildew and so do clothes
If the odor does not go away, it is probably time to change the rubber door boot, or you have something stuck in the drain. Take a good look at the rubber around the door. If it has mildew spots and/or mold, it generally won't go away. Pull the rubber back a bit and look BEHIND the boot as well. You may have some lost items stuck in the boot causing the odor. Last of all, UNPLUG the washer and remove the lower kick panel under the door by removing the three 7mm screws and check the drain pump for foreign objects. There's only one pump inside the washer so it won't be too hard to find. It is usually white in color and has a screw off access cover. There is a bit of residual water that remains in the wash tub all the time. You will need to drain this first or you will have a mess to clean up. You can use some towels or use a shop vac. If you use towels, lay them down around the drain pump and remove the access cover. If you use a shop vac, pull all the residual water from the wash tub through the drain line. Sometimes this pump will build up with all kinds of scunge from soap residue and/or foreign object getting caught. Clean it out real well and run the washer on a bleach cycle with the hottest water setting you have. Let me know if any of this helps you. If you decide to change to door boot, post a response to this solution and I will give you step-by-step procedures.
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Health & Beauty Logo
603 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
