Question about Xerox 8825 Copier
We have a Xerox 8825. When we scan a print that is 18' x 24" it prints on the 36" paper roll rather than the 24" roll. What is causing this & how we change it? We have never had this problem before.
    New Friend:
  • 51 Answers
Pls select the roll manually
Posted on Dec 12, 2010
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
Xerox 6600dn can it scan slides
If you mean can the printer print onto film slide to display on an overhead projector then I'm almost sure it can, however ensure the slides are of reputable quality i.e. Xerox slide material because the material will fuse and stick inside the fuser causing an expensive mess to rectify.
Good Luck.
Mar 20, 2014 | Xerox Corporation Phaser 6600DN Laser...
Not printing on edge of paper
pls check the developer qnty
Jun 17, 2009 | Xerox 8825 Copier
DC 1250 Paper Jam when printing few copies
Well that problem is because there is not enought oil on the fuser roll. The problem is the oil pump. change it before make one irreversible damage to the fuser or pressure rolls. Do a full maintenance of the fuser module.
Apr 25, 2009 | Xerox DocuColor 12 Printer
Dot line type comes out look like solid line type when printed
reboot your computer and controller and printer
Apr 08, 2009 | Xerox 8825 Copier
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Xerox 8825
hi im jules_09.have you tried changing you cleaning blade or roller?if yes check the exposure lamp my its deffective if not.also black copy is cause by over tone developer is also deffective
Oct 02, 2007 | Xerox 8825 Copier
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
