Question about Uniden GMR 635-2CK 2-Way Radio
There is static when you call or when trying to talk to someone.
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
Cb puts out good sound but when someone try to talk to me it all you hear is static
same thing sometimes happens to me. Usually it is because the person who is talking to you might have a weaker antenna. Sometimes people put a very strong transmitter with them and talk to people but you cant talk back.
So really they can't hear you good either. Just because you are too far away.
Jan 11, 2011 | Cobra 29 LTD CB Radio
Ref. Cobra 29 Radio: Can talk out and be heard but when someone is talking to me, sometimes I cannot hear them or it has a lot of static. Have tried everything. Please make suggestion.
HI, my name is John. Try putting the RF GAIN to MAX,also the squelch, check the antenna connections, have someone check your SWR, they can do it at Radio Shack for free, or a CB shack. If that does not help, let me know and we will go further with it....hope this was helpful...oh, and turn on the NB or the NBL switch..
Sep 02, 2010 | Cobra 29 LTD CB Radio
Midland GXT550VP4 communication problems
Did you use the sub-codes? Where they tested indoors or out?
Dec 23, 2007 | Midland GXT550VP4 (7 Channels) 2-Way Radio
Static
git a good grond on it or it will go sky hi
Dec 05, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
How do i get rid of this annoying static?
Static is caused by one a weak signal and two a defective circuit board in the phone.
Apr 08, 2017 | Sony Ericsson Z520a Headset Headset
Uniden GMR 635-2CK 2-Way Radio Logo
20 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
