Question about Mag Innovision LT776s 17" LCD Monitor
RE: Replace 16v 1000uf
I have a lot of 25v 470uf caps at hand and wanted to know if it would do any harm in replacing the blown cap with this type. The pcb specifies 10v 1000uf!
  • igi_54 May 31, 2008
    Thanks for your input, went out and bought a 25v 1000uf cap and it works again! Thanks heaps!!
  • 4,234 Answers
You can change the voltage rating to a higher one without compromizing the circuit. You can not lower the value however. In other words, using a 1000uF cap rated at 16V would be OK. The short answer is no, you can not use the extra caps you have unless you put 3 of them in series. (I doubt you have the space for that.)
Dan
Posted on May 29, 2008
How to fix a mitsubishi dm board
There are 7 capacitors that will require replacement.I am attaching a picture. Use 1000UF 25V caps hen replacing the stock 1000UF 16V caps that are currently installed. if you need further assistance let me know10_6_2011_3_26_47_am.jpg
Oct 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws 65513
Yes, 1000UF 25v would be fine. just replace all capacitors in DM Board.
Need further help, let me know.
Regards,
Sep 14, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Need to know where capacitors are on mitsubishi ws 55511 tv are located at have back of tv off and cant locate them please help thanx
they are located inside the DM modules case( Metal Case on far left side ) open the metal case and you will see 7 caps on the DM power board. I am posting a pic of the board with the 7 caps that need replacement use 1000UF 25V caps to replace the 1000UF 16V caps that are currently installed.
Aug 08, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I am trying to find out how to identify the capacitors to replace on the DM board. Do you have an illustration that shows me which caps to remove?
There are 7 1000UF 16V capacitors. Replace them with 1000UF 25V radial caps 105 degree celsius works best. Below is a picture of the 7 caps.slinteriors_12.jpg
Jul 16, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a samsung syncmaster 740 N screen, and it's dead (the power light is on, and the screen remains black, no "no signal" indication or anything). my warranty has expired. is there anything i can do ?...
Open it up and check the caps in the power supply. Check to see if the tops of the cans are bulging. Look to see if there leakage coming from any cap. If the caps are 25v I usually replace them with 35v and use the same ufd's as the old cap. This is usually the fix for this problem, Hope this is helpful.
Dec 13, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
37mf23id magnavox takes 15 min to come on . its a magnavox which is made by philips
You need to replace the power board,Or replace the capactors on it.
Replacing the capactors is the best idea.They are under rated at 10volt insted of 16volt or higher. They cost less too. If you replace the board,you will still have the same problem again later. They are usualy 680uf 10v,1000uf 10v,2200uf 10v,and 3300uf 10v. Replace them with the same uf but 16v or 25v EXPANPLE use... 1000uf 16v or 1000uf 25v
They are polorised Blak spot on board is the - side of cap. Stripe on cap is -. The caps. swell if they are bad. The tops round out,or the X on top breaks anfand black or brown goo comes out. Top should be flat. It I can assist you further please feel free to ask. toddthetvmd@yahoo.com
Oct 27, 2009 | Philips Televison & Video
CAPACITOR 1000 UFD 16V 105C FOR MITSUBISHI WD-52525 52 IN. TV
no you cannot substitute a 680uf 16v 105c in place of a 1000uf
if you want to put a better capacitor in place of the old 1000uf 16v 105c , then use a 1000uf 25v or 35v 105c
the voltage rating will allow the cap to better handle the circuit
Apr 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Philips 20ps47s301 turns on then starts clicking and turns off
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
Jan 16, 2009 | Philips 20PS40S 20" TV
Viewsonic lcd problem
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Jan 06, 2008 | ViewSonic VX924 19" LCD Monitor
Acer AL2021
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Jul 10, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
905 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
